Oil passing out of the gearbox
I have a dry clutch and belt drive in my dominator.
After running the bike for about 400 miles, I've got oil coming out of the gearbox and into the primary drive section.
Has any body had this before, and does any body know how to cure this.
hi,
this can be a issue,the oil if its from the gearbox it is possibly travelling through the mainshaft ,
there is a bush in the mainshaft and they do wear out,it needs to be replaced,
norvil do a fix for this with a oil seal on the end of the mainshaft,check that they still supply these,
i have also in the past cut the clutch pushrod in half and placed a ball bearing between the two rods with some silicon applied around the rod at the gearbox end,its a bit of a bodge but i,ve had to work,
