Featherbed Oil Tank/Battery Box
Does anyone have any close up pictures of the fitting to the frame of a featherbed the original type oil tank and battery box.
Original type featherbed Dominator oil tank sits along side an exposed battery. No battery box up to 1956.
There is a steel platform for both. The oil tank has two studs + nuts to hold the base to the platform, and a tag welded to the top to bolt the oil tank to the side of the tool tray. Sorry no pics
If you are talking about a featherbed International, it's all a whole lot wider. The oil tank has a much larger capacity, and it is through=bolted like a Manx oil tank. Same exposed battery
hello battery boxeswere fitted from September1955 on featherbed frames the same year the model 99 was introduced as a 1956 model before this everything was as 1952 to September1955 batteryin a bakelite box and clampedon to the platform yours anna j
