All Forum Posts
Tail light 1957 Dommie 99
I'm a newbie to the Norton Family, have recently bought a 1957 Dominator 99.  I love the bike, but have noticed the rear light isn't working.  I've dismantled the unit and the wires at the base of the bulb holder aren't connected to anything.
Blowing fuse
So there we were about to join the A66 at Barnard Castle on the Commando and everything went out without any warning. Blown main fuse. Replaced it and rode home 60 miles no problem. Must have been age and vibration, I thought.
Mk1 cyl head removal
Hello
ive just joined as I have bought a commando Mk1 made 1973 from the USA. Paid the duty got the certificate of authenticity from the Vintage motorcycles club and DVLA have issued an age related plate and the V5....
Clutch Rubbers
Hi. Sorry, it's me again.  Do you have to warm the new clutch Rubbers up to fit them, as they're very hard and the assembly won't go back together as they are.  Thank you.
Glowing exhausts
Good afternoon all,
                              Question?Exhaust pipes glowing cherry red,whats your money on?incorrect ign timing or weak mixture?
MKIII LED conversion
Hi folks,
Is it possible to convert indicators to LED bulbs using both 062045LED flasher relay and 382LED bulbs (x4) for MKIII Commando which includes a deck flasher repetition bulb ?
Looking forward to hear about.
Jérôme
NOC Facebook Page adverts
How come we get members advertising things that are nothing to do with Nortons or even motorbikes on our FB page. One person had multiple adverts for household doors and today we have someone advertising Monopoly games.
bearings
I seem to have aquired some new FAG bearings, ref NU306E M1,  bronze cages , suitable for a Dommy?  suspect they may be a thou OS to fit in slightly worn housings ?.
1936 model 19
hi can anyone help pls ....does anybody know if theres a suitable piston that can be used past a 60 thou oversize poss 80
thou    thank you
CS1 Moore bevel/spline
Hi
My 1928 CS1 engine is complete, but there is a lot of backlash between the vertical shaft spline and the bottom bevel. It seems like the wear is in the bottom bevel where the spline runs. The shaft splines look good.
roadholder dampers
I have a 1969 Mercury SS.  The steering dampers normally have two holes drilled, but mine has four holes.  Can anybody tell me why my dampers would have four holes and the reason for it.  Would appreciate if somebody could throw some light on why
