All Forum Posts
Monoblock games
I have been  trying to get my 99 to run better,  First it was rich,  dirty plugs.But went like a rocket while running A new needle jet and nearly seized it up!.
Finished at last
So after 9 months in the building I’ve finally finished my Norton Metisse, well except for the front mudguard that needs a bit if fettling before I fit the proper one.
Speedo drive
I have a spare drive  that needs work ,it is marked 19/10 and BG5330/847 , not sure what it  came from . Is it likely to be any use on a Chrono featherbed 99 or Atlas with magnetic speedo??.
1962 Dommie 99 rewire
Hello my bike is 12v +ve earth with magneto and 2 wire alternator, zener diode and little 4 prong solid state rectifier  Wiring is bit of a mess but all works ammeter indicates a charge  There is no ignition key just a mag kill switch.
Drive side oil seal.
Advice please. I want to replace the drive side oil seal from within the chain case. What tools are required to pull off the rotor and chain sprocket. Is the seal behind the round fixed plate.
John
Indicators
When did Norton start adding indicators to Commandos please?
I have a 1972 750cc, recently purchased but without indicators and wondered if this is correct.
