All Forum Posts
Gearbox foot change
Hi can anyone help me with the orientation of the pawl spring washer with the pawl spring.The washer has a long and a short flange on the circumference, I need to know which fits between the legs of the spring.Regards
16h drive side drain hole
On the drive side crankcase there is a small hole behind the main bearings, at 6 o'clock, which doesn't appear to be threaded (see pics).  Is this a drain hole?  There is also a groove in the crankcase above the hole with a small channel.
Rev-counter gearbox
I have a two-into-one issue with a couple of tachometer gearboxes, both of which are faulty in different ways but with which I hope to perform the two-into-one trick in order to obtain a functioning item.
chain wash'n'brush up
Following an earlier forum on the topic of the now- discontinued Linklife, I have come across "Kettenmax", a German product that is literally a wash and brushup. In short, a small plastic box that opens to be clamped round the rear chain.
distributor
have just bought 1962 es2. the distributor is partialy dismantled. I need the sequence of the points and insulating washers if any one can help. The maintenance manual is not specific enough.
Pat Chambers.
long roadholder forks
hi,i am about to replace the stanchions in my m7 long roadholder forks,noting there is a conversion kit to improve the damping available,containing new damper rods etc.,also stanchions (at extra cost).question is,has anyone tried this conversion,a
I think I was almost scammed
Earlier this month I put a Wanted in the Classified for an Electra rear hub/sprocket. Got an email this morning asking was I still looking. Replied yes, got 2nd email " Let me know the year and model of yours to ensure the right one . "
