All Forum Posts
Fixed! Bent Navigator Frame
Hi all, 5 weeks ago after 40 years safely avoiding car drivers pulling out in front of me I finally fell victim to a real expert and in avoiding him / her I came off my beloved Navigator breaking my wrist.   Very luckily the bike and I only hit th
Dzus Fasteners for panels
I mentioned this a number of years ago - these are available from LAS Aerospace based in Okehampton, Devon and they come with an Airworthiness Certificate (or similar)!  Worth considering if you often reach take-off speed over humpbacks!
ES2 1955 - Head and Carb
Hi all,
I've just gained a new project 1955 ES2. This is all new to me since my other Norton's are Commando's. I'm still gaining information and have yet to source a parts book, which I'm sure would help with this question - anyway!...
1936 16H
Hiya,
Okay so I’ve got my new tyres for the old bike. Turns out the one on the rear, they stopped making in the early eighties, so definitely time to renew!
Cam Chain Longevity
I am the only owner/rider owner of my 1972 Combat Interstate Commando.  My question is about the life of the cam chain and its sprockets.  My Norton has ~ 50,000 miles and the chain has been kept in proper adjustment.
Speedo Drives
I have read that drives for Royal Enfield  may work on a Dominator, As they are a fraction of the price of drives for Nortons but possibly made in the same place?? , I am  interested,Has anyone any information?.
Exhaust pipe bluing
My left side pipe is very yellowed and has significant bluing patches...probably a result of the previous owner running that cylinder a bit too lean. Who has successfully removed it? How?
kick start travel
I have a lay down g/box and find that the kick start doesn't seem to engage until it's about half way down. I can still start the bike (ES2) but it would be so much easier if I could get a good real swing at it. Any clues as to the prob.
fork seal holder
Hi, I want to replace the chromed fork seal holder on my 62 navigator delux, but not sure if the wider roadholder forks are classed as "short roadholders". Can anyone help?
Cheers,
John Braithwaite.
Gearbox cover O-rings
Hi. I’m rebuilding the gearbox outer cover of my Dommie 99 and want to replace the two O-rings (the one that sits between the kickstart bush and the cover and the one that sits between the gear selector shaft bush and the cover).
Clutch hub extractor
I am trying to get the clutch hub off the gearbox shaft on my 99.
It is in position very tightly and there is no way to lever it from behind.
It has an internal thread which obviously takes an extractor tool.
Replacement gauges
Hi all,  recently purchased a 1975 Mark3 that has been sitting since 2005. Serial number on motor is 325084.  Can not find any marking on frame?  Will be doing all the correct things to re commision her before attempt a start up.
Mk. 2 Amals
Hi all,
Coming to the end of a rebuild of my 750 Commando and have just bought a pair of unused Mk. 2 Amal’s from a friend who does not need them anymore. They are 32 mm as are my ports and are fitted with no.3 slides and 240 main jets.
