All Forum Posts
Locked kickstart
Annoyed with myself that I cannot sort this......
had to replace the rear brake drum sprocket, so also fitted new chain and gearbox sprocket obviously needing complete dismantling of primary side.
Orange paint
Hi, unfortunatley Ive had a disaster with my Orange 850 commando petrol tank with fuel leaking under the paint and bubbling it up so I need it repainted.
Matching numbers
There is a Norton Atlas for sale in Finland, 1962, frame & engine number 101866 and then 20 for the Atlas model. I wonder whether this can be correct? Best Regards Ragnar
Pazon timing hole
Hi, I’m fitting a pazon electronic ignition to my Electra. Could someone who has fitted one of these please tell me which timing hole to use on the trigger plate.
cheers, Stew
Yesteryear
Yearning for yesteryear and the great smell of Gunk I bought a 5 litre can.
What's happened to the original smell?
Hole in piston
This happened after a couple of minutes at 70mph some years ago. I blamed preignition at the time, but I heard no pinking. It permanently knocked my confidence in the bike. But there is no sign of preignition burning the carbon off the piston.
Latest survey
Just completed the latest survey and can’t see how it would help the club to plan for the future, as there was no where to leave comments or suggestions. What do other members think?
oil pump
I purchased a 1969 commando .IN A BASKET . Can any one advise on the oil pump stud pitch sizes . Crank case end. I ordered 2 studs from RGM witch are whitworth .the case is fine pitch poss BSC
Mk2 A Battery
Hello.
Can someone advise me what battery will fit into a Mk2 A Roadster battery tray to run  my Alton electric starter, I have a Motobatt MB9U battery in at the moment and is 11 Amp rating and not the 18 Amps that Alton requires.
