Drive side crankshaft
62 Slimline 88 std.
Q. Is the drive side crankshaft a COMMON SIZE with later 12v Atlas, Mercury, Commando etc ??? Ie any/all rotors will fit shaft?
Need to resolve charging problem so going 6v to 12v. Is the alternator/stator housing common to all models ???
Sorry if wrong sub section but not getting replies on Electrical section.
thanks, John
Previously john_baker2 wrote:
62 Slimline 88 std.
thanks, John
Try Electrexworld.com for a upgrade Yours Anna J
Hi John, yes it is. No no commonality issues. Go ahead and convert to 12 volts - you won't regret it.
62 Slimline 88 std.
thanks, John
hello some Lucas Rotors
may need shimming ,yours anna j
Thanks...thats a start !! all I need now is to find a wiring diag that I can understand.
Have raised query on Electrical section so here's hoping I get some replies.
regards John
regards John
well to start with we need to know what machine it is, and Q like a magneto model or distributor model . and then the year of the machine would come in handy too, yours anna j
AJD...conversation started with 62 88 Slimline std....which indicates year and model. Std indicates coil/dist.
All in full on the ELECTRICAL section as I thought that was the correct place for this query. I have now had a couple of replies there....BUT of course all help is appreciated.
regards John
