62 Slimline 88 std.
Q. Is the drive side crankshaft a COMMON SIZE with later 12v Atlas, Mercury, Commando etc ??? Ie any/all rotors will fit shaft?
Need to resolve charging problem so going 6v to 12v. Is the alternator/stator housing common to all models ???
Sorry if wrong sub section but not getting replies on Electrical section.
thanks, John
Hi John, yes it is. No no…
Hi John, yes it is. No no commonality issues. Go ahead and convert to 12 volts - you won't regret it.
Previously john_baker2 wro…
hello some Lucas Rotors62 Slimline 88 std.
thanks, John
may need shimming ,yours anna j
Thanks...thats a start !!…
Thanks...thats a start !! all I need now is to find a wiring diag that I can understand.
Have raised query on Electrical section so here's hoping I get some replies.
regards John
regards John
well to start with we need to know what machine it is, and Q like a magneto model or distributor model . and then the year of the machine would come in handy too, yours anna j
AJD...conversation started…
AJD...conversation started with 62 88 Slimline std....which indicates year and model. Std indicates coil/dist.
All in full on the ELECTRICAL section as I thought that was the correct place for this query. I have now had a couple of replies there....BUT of course all help is appreciated.
regards John
Try Electrexworld.com for a upgrade Yours Anna J
