ES2 weight
Hello ,
can some one help me with the maximum weight for a 1951 es2
I have the dry and wet weigth but need the maximum load weigh, i look in books but can not find any info .
Many thanks if some one out there can help.
peter
Is this linked to a registration application outside of the UK ? The maximum all-up weight is not really a concept that was applied to motorcycles in the UK during the 1950s...maximum weight was Mum, Dad, two kids and luggage in a double-adult sidecar !
I have recently seen a document produced for the German authorities regarding a WD16H (which is probably a little lighter than a plunger ES2) and this gives an unladen weight of 160kg with a maximum permitted weight of 350kg...I can only imagine what a 350kg rigid Norton handles like....
It may well be that Norton Deutschland could help you as this seems to be a long-standing requirement in Germany.
hello thanks
it goes about about try to import into switzerland .they need this for the road tax, power (ps) x weight(kgs) it is needed for the papers (logbook). To find all the info that they need is a problem ,
Isn't the UK limit for three wheelers set at 8 cwt? (8 hundredweight is 407kg). That will give you plenty of scope for a vast side car although you'd never get up those mountains, and you'd never stop on the way down.
