My original Norton Maintenance Manual & Instruction Book (Publication 105/P) for my 1964 Navigator quotes the 'oil tank capacity as 3 1/2 pints with the oil level 2" below the edge of the filler orifice'. Filling the tank with 3 1/2 pints puts the tank level mighty low and a bit more than 2" below the bottom of the filler although difficult to measure accurately. Do those who have long term experience of the Navi' stick to 3 1/2 pts or aim for the 2" level? I have previously over filled the tank in my enthusiasm for good lubrication which resulted in a beautifully lubricated rear chain...â?.rear wheel, exhaust and garage floor even though the engine, gearbox and primary side aren't leaking! I would welcome any top tips!
Nick
Possibly the oil tank on t…
Possibly the oil tank on the Standard might be a slightly difference capacity to the De Luxe tank. I normally put in the 3 1/2 pints ( 2 litres ) and leave it at that but the oil level in the standard tank always looks down a bit ; on the De Luxe there is a dip stick with markings. 2 litres of oil should be plenty for a low stressed 350 engine so as long as the tank is half full it should be quite happy.
If you have an external oil filter this will hold some extra oil.
Your later 1964 Maintenance Manual is obviously updated - I have a 1959 one and also a 1963 one and both of them only refer to the oil tank on the De Luxe - i.e it says to keep the oil level between the Minimum and the Maximum marks !!.
Patrick
Many thanks Dan and Patric…
Many thanks Dan and Patrick,
I suspect I have been over generous through a natural desire to ensure plenty of oil capacity - I probably put 4 1/2pts in at the last oil change! I think you are right, 3 1/2 pts should be more than enough for a 350 and Dan's '2 knuckle' rule sounds about right and certainly below where I have it at the moment which is less than when I did the last oil change. I have checked the gearbox & primary case levels and they haven't lost anything in 500 miles of brisk motoring, only the engine oil has dropped about 3/4" with no evidence of leaks apart from round the chain and nearside behind the final drive sprocket. There is no significant blow by so I'm going to assume I've over filled it and drain the tank down to the 2" / 2 knuckle point, degrease the back end and see how much leaks over the next 500 miles. At the next oil change I will use 3 1/2 pts and see if that is the answer!
Nick
Does this mean the recomme…
Does this mean the recommended oil level decal also goes 2â
below the edge of the filler orifice?
Haven't fixed it yet.
My take on this is slightl…
My take on this is slightly different for me the main oil tank is simply as a resevoir to store and allow the oil to cool before serving the oil pump for dry sump lubrication. After a run when I drained the sump filter and measured the quantity of oil in the (dry)sump, for my bike it was approx 1/2 a pint of oil, and I take this as the approximate normal running amount swilling around the crankcase. The quantity of oil in the oil tank simply affects the running temperature of the oil circulating. Too much oil in the oil tank is going to spill out, too little is going to run the engine hotter.
GRAHAM
Ulrich, my Navigator doesn…
Ulrich, my Navigator doesn't have the transfer, I suspect it wore of decades ago! I had a very late Jubilee back in the late 70's and that had the decal on the tank at what I remember to be about 2" down from the bottom of the filler neck so that is where I'm going to put mine.
Graham, I'm not sure how much oil will remain in the bottom of the crank case when you switch the engine off but the scavenge side of the pump runs at a higher capacity to the pressure side so it shouldn't have much left in it - 1/2 pt seems rather a lot. For example when my engine first starts the return flow is constant but after it has been running for a few minutes the return is becomes slightly intermittent at tick over as the pump has sucked the sump almost dry. I suspect most lightweight twins 'wet sump' so if you leave the bike standing for any length of time oil will slowly drain past the pump back into the sump. I'm going to go with what Norton recommended and fill mine with 3 1/2 Pts. Experimenting this morning with the oil level about 1" below the filler neck and leaning the bike over it very quickly had the oil up to the level of the breather / chain lubricating pipe hence my 'over oiling' of the chain! A useful lesson learnt in trusting the maintenance manual!
Nick
Previously Nick Clarke wro…
Nick
Hi Nick The recommended oil change is every 3000 miles. I remove my sump filter every 500 to clean and inspect.It gives an early sign if something has changed. I get a 5cc teardrop of oil under the bike whether I drive 10miles or 200miles or leave the bike standing for weeks.So the level of oil in the sump does not give me a problem. The oil tank filler cap weeps a bit over the oil tank, but an oily rag sorts that. It would be useful to know the volume of oil that is in the sump of other lightweights to compare.
GRAHAM
Hi Graham, being neurotic…
Hi Graham, being neurotic about the Norton's lack of proper oil filtration and having not yet fitted a remote spin on filter (a mod which seems to offer its own challenges....I would welcome any top tips if anyone has them!) I fitted the NOC magnetic sump plug mod which allows me to remove the plug and do a health check for signs of bearing wear at 500 miles and then change the oil and clean the strainer at 1000 miles adding Molyslip for a bit of extra protection. I work on the principle that oil is cheaper than an early engine rebuild! This cautious approach has worked well with my different classic bikes and cars over the years. I will report back in a week or so when I reach the next 500 mile mark.
Nick
Hi Nick, If it's any help…
Hi Nick, If it's any help I recently fitted an oil filter and then added oil to bring it up to 2" below the filler. Haven't done many miles since but seems okay so far.
Dave.
Attachments in-line-filter-jpgThanks Dave, that is very…
Thanks Dave, that is very helpful and looks very neat with good routing for the oil pipes. Did you make up a bracket to bolt it to the frame using the two existing bolt holes that the centre stand stop bolts to at the bottom of the main frame vertical 3/4 box section?
Nick
Hi Nick, I first got a bra…
Hi Nick, I first got a bracket from the NOC shop but was concerned that the centre stand rubbed the oil pipes. I drilled a couple of holes about 3" above the centre stand stop fixing, made a bracket to suspend and turn the filter across the bike and keep the pipes clear of the stand. I also added a mud flap to the rear mudguard to try and keep that area a bit cleaner, will have to wait and see whether that was a waste of time!
Dave
Thanks Dave, it sounds lik…
Thanks Dave, it sounds like an elegant and well thought out solution - looking at your photo I can see how that would work. Given the need to access that part of the frame I suspect one to wait until it is time for a full restoration! keep me posted!
Nick
Well chaps, final update.…
Well chaps, final update. Lowering the oil level to 2" below the filler neck has cured the leak which is a salutary lesson in trusting the Norton manual! Thanks for the advice - as a routine health check I removed the magnetic sump plug and was very pleased to find it completely devoid of debris which is encouraging. When I last changed the oil 400 miles ago I used flushing oil before draining the system, removed and washed out the oil tank with petrol, cleaned the gauze tank strainer and replaced the sump strainer. After running the engine at tick over for 30 mins with the flushing oil the mag plug had a very fine 'fuzz' of micro filings on - I suspect this was years of wear debris which had been flushed out. Only about 20cc of oil drained out from the crank case but that was only 5 mins after a brisk run. Onwards and upwards!
Nick
I have also found the Dan…
I have also found the Dan F 'knuckle' level adjuster, very straight forward. And we also have the ritual of starting and running the engine for 5 mins before going out to bring the oil back into the tank from the sump. The other funny thing on the Electra was the very short side stand, such that the bike almost fell over unless I parked the stand on a kerb or 4" brick. But then one day trying to fill the silly oil tank neck which is almost impossiible, as it hides under the seat edge, I realized that if you leant the bike over on the side stand then the oil tank filler was nearly out in the open! Then I discovered the plastic tube built in to Morrisons oil 'cans'.
Ps we have spelling mistakes above but of course we do not have a proper spell checker!
I agree Alan, Dan's '2 k…
I agree Alan, Dan's '2 knuckle' guide works a treat - a good example of a 'KISS' solution! I have resorted to using a big 60ml syringe with a length of clear plastic tubing attached and a tie wrap 2" from the end. I fill the tank with the correct amount of oil and then use the tie wrap as a guide to remove any extra. As for the side stand I have heard similar tales of woe....and have been put of by the sheer cost of the side stand advertised in the NOC shop....and a deep distrust of side stands!
Correct on trust of side s…
Correct on trust of side stands, I have a Moto Guzzi (no comments please it is quite wonderfull (more spleiling mistake still no proper spell checker) doesn't leak oil for one) which due to a silly factory mod to have 16" wheals in the 1980's made it with a short side stand, to get the bike to behave properly we had to fit 18" wheels, so now the side doesn't reach the floor. ie you flick the side stand down and then start to get off-the side stand doesn't touch the ground hence it folds up and you with it....so have to fit a side stand extension.
Back to the Electra that side stand was too short and I decided that the frame clamp could have its angle altered by cutting and welding, on the second attempt it is near enough to use, but I still view side stands with trepidation.
What has this got to do with Navigator oil level? nothing.-off top-pick again.
Fear not Alan, I also have…
Fear not Alan, I also have to admit to a dark secret that I still own a Le Mans II I bought in 1986 and still love with a passion..â?...apart from its dubious side stand which has repeatedly let it fall over not doing the left hand faring, the tank or my back any good!!! I am slowly restoring it but enjoying the Navigator too much so that job is on hold until the winter!
I use my index finger as a dipstick, Its about 2 inches from my knuckle to the tip! But it leaks a lot at the moment, so goes up and down a fair bit! I wouldnât let it go more than half empty.
dan
