000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
Magneto sprocket key way?
Just removed the magneto sprocket on my 1935Es2, after a struggle. The sprocket doesn't have a key way slot and neither does any that I have seen for sale i.e. Rgm and racing Norton, but the magneto shaft does. Any idea why this is the case? Also the shaft isn't anywhere near central in relation to the aperture in the case. I'm thinking maybe that's why the sprocket was such a pig to remove as the boss on the sprocket was stuck on the inside of the aperture in someway. I need advice please if someone can help.
No key - mag sprocket needs to be able to be positioned about the shaft to set the timing . The taper fit is more than adequate to keep it from slipping. They are indeed difficult to remove as you discovered.
There are several threads somewhere describing tools that can be made to aid in removal.
If the taper is in decent condition there's no need fr anything else. If not, lap it in with some fine grinding paste.
Privacy Policy
