Just removed the magneto sprocket on my 1935Es2, after a struggle. The sprocket doesn't have a key way slot and neither does any that I have seen for sale i.e. Rgm and racing Norton, but the magneto shaft does. Any idea why this is the case? Also the shaft isn't anywhere near central in relation to the aperture in the case. I'm thinking maybe that's why the sprocket was such a pig to remove as the boss on the sprocket was stuck on the inside of the aperture in someway. I need advice please if someone can help.
None do its tapered fit...if…
No key - mag sprocket needs…
No key - mag sprocket needs to be able to be positioned about the shaft to set the timing . The taper fit is more than adequate to keep it from slipping. They are indeed difficult to remove as you discovered.
There are several threads somewhere describing tools that can be made to aid in removal.
Check this device out.....
......could make the task much easier. Untried and not necessarily endorsed.
And in agreement with David; no Loctite here!
I would not glue it. You or…
I would not glue it. You or your successor will suffer for it...
None do its tapered fit...if your worried stick some threadlock on it.
