What should the clearance be between the dummy shaft and the center bore of the drum? Tbh I think there is some wear due to previous lack of maintenance can anyone measure a new part please??
It's not a bearing surface
Load bearing surface
Thanks Ian, that also makes sense.
I was a little concerned since the hole looked offset to the hub so wasn’t sure. There is around 3mm radial clearance.
I think that's normal.
I think that's normal.Allows for the brake to center.
so clearance there isn't a problem. The 2 row bearing takes all the forces.
