I'm probably just 'man-looking' as my wife would say, but I can't seem to find Navigator front wheel bearings in the Lightweight section of the NOC Shop. Can anyone point me in the right direction please? Also any top tips on removing and replacing them.
Thanks, Nick.
Roadholder forks so maybe…
Easily available from simply…
Easily available from simply bearings etc - just check the number I think it’s 6203?
Navigator wheel bearings
Nick, If you go to NOC shop, Spares, Lightweights then down left hand side to bearings, you will find -
17721 . . Parts List No EA18 . . RH, double row 17x40x16 . . SKF 4203
17719 . . Parts List No EA22 . . LH, single row 17x40x12 . . SKF 6203
Or as Dan said, go to your nearest bearing specialist.
Hope this helps
Roadholder forks so maybe look in the Heavyweight listings?
