I am looking to have collected a Model 50 engine (no primary, mag, carb etc) by courier. It appears if it is under 50kg (110 lbs) it can go as a parcel which is much cheaper othewise I will need to use a pallett service.
So a bit of an obscure question but anybody know how much the engine weighs?
An indication - just this…
You will need to allow for…
You will need to allow for boxing it up which will probably add a few kg.
I wouldn't like to be the courier having to load 50 kg parcels!
Is it a complete engine? I…
Is it a complete engine? I sent an ES2 iron engine by courier a few years ago. Because it was disasembled I sent it in 2 boxes and it worked out cheaper as they where both under a weight threshold. I can't remember what the weights were, sorry, but it might be something to look into.
Andy
An indication - just this morning I dragged an old 16H engine out onto the bench. It weights 33kg. Iron barrel and head. No magdyno.
