Navigator Deluxe oil feed
Hi can some one let me know witch oil pipes go were.
as regards to oil feed to engine, on the navigator deluxe oil tank.
many thanks John.
Hello John,
I take it that you are aware that the De Luxe oil tank is different to the Standard oil tank - so the parts you require are specific to the De Luxe model, either Jubilee or Navigator. I have noticed that Ebay tanks for the De Luxe usually have these fittings missing - so they could be difficult to find.
Patrick.
many thanks John.
I would work things out from the oilpump.On theJubilee and Electra looking at the pump the outside hose is the oil feed this will come from the bottom of the tank the inside hose is the return this will have a T in it and empty into the top of the tank any other outlets are a vent or breather return, The T is for the rocker feed pipe, Bryon
many thanks John.
Thanks Bryon
its the banjo that's missing. The feed is the one with filter.
Return back into tank and rockers.
