Front ISO upper mounting bolt
Hello,
I am trying to remove the front ISO mountand no matter what I try I can't get the upper bolt out. I managed to get the nut off and it turns, I can drift it out until the timing side end of the bolt is flush with the mount, but that is it. No amount of turning or pullingwill budge itany further. I am thinking I will have to hacksaw the bolt head off from the drive side drift it back through a bit at a time and hacksaw off the exposed bits on the timing side.
Hopefully someone can offer a better idea?
thanks,
Gerald
I think you are probably on the right lines. I have a dremmel type tool and the genuine dremmel grinding disc and mandrel saves a lot of time provided you protect the surrounds from the sparks. Treat yourself.
