Front Brake Mod's
Yesterday, i managed to fabricate/modify a Brake scoop for my Norton special. I purchased from a Breakers a part consisting of small Yamaha engine casing with 2 bolt holes cast in it, for a fiver!
I took my Pre-1955? Birmal front brake plate which had been previously used on a "Dommi'e" 99 Special race bike and copiously drilled with cooling holes used in conjunction with a Pre-1955 composite drum and matched the proposed part up for size and coverage of said drilling! The front of the engine casing was cut out to allow for an air intake and now all i need is some mesh to stop grit particles from entering the mechanism!
The Front Brake plate was further drilled and tapped and after a session on the polishing wheel for both parts was put together and for said fiver and some three hours getting dirty hands, I have something that looks very passable and has cost virtually nothing to pit together! Use of a friend's workshop much appreciated!
John H
Brake scoop, Photos will follow!
I have moded bikes scince the 70's purchest second hand and new. If it did not meet my requirements. Handle bars, brakes, footrests, luggage, seats.
Now I have a Commando which cost a small fortune to get back on the road. I have used jap parts to get it working, when I could not get original parts. You have to look else where when parts are not advailable or when they do not come up to the job.
Hello well, this may all look the part But it's a whole lot of work with little in the way of effectiveresults, as the Brakes will work just as good when time is spent setting them up right. yours anna j
Ummh!
EER! Clever Clogs, this is before I have put them, (the brakes that is), together and the cooling air coming in will make them more effective, plus i have only added a reasonable sized air scoop for "road" use as I am not on a Race track, yet!
Have you done my radiator frame and combined oil cooler rack yet? The little job I gave you to do before TT practice week?
How dare you criticise my policy of restoration, my mate Anna!
I will upload a photo presently in the week!
John H
Previously john_hall1 wrote:
Ummh!
John H
Just teasing mate, I know how busy you have been!
John H
Hi John
I too like to modify things and appreciate your ingenuity in using a Japanese engine case for your air scoop.
My 99 has a modified front brake plate that has had an air scoop added sometime before I acquired the machine (see pic below). As you can see, the intake area is massive compared to the four small exit holes so I doubt very much that there is any significant air flow through the brake.
Now, I have been known to ride my bike very hard and I use the brakes also very hard on the B roads and lanes in my locality, but have never managed to induce brake fade - even going downhill. (Perhaps holding the throttle on full and brakes on full it maybe possible). I can see that the mod maybe beneficial if we were to live in the Alps and ride two up, but for me (apart from the looks), all I can imagine happening is that the scoop allows copious amounts of water into the brake drum during wet weather riding.
Is your reason for doing this mod to reduce brake fade, or purely for aesthetics?
https://s20.postimg.org/milh4xnd9/IMG_1267.jpg
Hi Bob,
A bit of both! The Norton Special will have a modified 930cc Hillman Imp engine fitted, I want it to go but I also want it to stop and thinking if heat causes fade then eliminating heat will help the brakes work more efficiently too!
It's a modest scoop, I wanted to try and make the brake as good as possible, but the pre-1955 brake plate I have, had been used previously in a "99" racing special and was already pre drilled, so I wanted to make the drilling less unsightly and more effective, if you look closely at the photo you can see it looks like a previous scoop was fitted possibly by Araldite or some such stuff!
For me it's function first and then form, I studied Biology and Ecology, the Natural Sciences, when I was younger and was interested in how nature has designed living creatures, but essentially nature's mechanism is always function followed by beautifully designed forms!
I was interested in adapting designing a twin-leading shoe set up, I have both types of brake plate but consider the earlier Birmal type, though more old fashioned to be a superior casting to the strange form of the internally fitting later examples ( are they/were they Italian made?)!
On a American web page featuring a "Bath-tubbed" Norton 650 deluxe, his later brake plate has been adapted to a "Twin Leading shoe", in which it says it's a simple adaptation! But I can't find out anything about it any where!
I wondered why no-one has redesigned a Four brake Twin Single-leading shoe outfit that the Vincent used, apparently they are quite good!
They used to say it was the second emergency pull in quick succession to the first that caused fade to be lethal with air holes both kind of matched then this should help to stop this happening! I could get all anal-li-retentive and work out "Hole" area at the front and rear of the brake plate, and if my head clicks into this mode I may do that but I am not sure whether a slight back pressure may help with cooling?
I intend to ride my creation long distance and therefore require it to function as effectively as it can, across the Alps is funnily one of my ambitions!
Hope this help explain my raison d'etre, the bike will evolve rather than be statically stuck in some window of the past, forever, as it was birthed into the mechanical world!
John H
Yet again I cannot post an image as it's 1012 bytes and not the 1000 byte limit! Why doesn't someone just make it a Megabyte which is 1012 bytes!
Also:
Brake plate been cleaned and polished since this initial state of disrepair!
John
John:
How do you manage to prevent water/road spray/rain from entering the brake when things are wet about?
Hi, Mike,
it is a moderate sized scoop, but funnily enough what made me think the part was even more suitable was that there was two small holes in the back of the casing, probably there for electrical wires, but I thought they may act as water bleed holes!
If you were clever with an air-flow meter, I suppose someone could experiment with the best design of Air scoop, but if the Air scoop part is the coolest part then perhaps from a condensation point the water would be more liable to stick around in a scoop and bleed away from my two tiny holes than enter the brakes proper, (this may be wishful thinking), but until I try it I will not know, the effectiveness and because i haven't tried the original set up I will not know how much more effective it is, if any!
I had a BSA for 10 years with the 1970 TLS brake set-up on it and it never let me down, the problem now is finding mesh to suit like the BSA mesh sized set-up! According to the pundits the 1968-1970 TLS BSA Triumph set was was the best the Factories ever managed to produce!
I do not like the idea of the standard Commando set-up which needs a strengthening plate, this shouts of something being wrong in the initial design! RGM do the same set-up, but the brake plate itself is reinforced a better idea I would think, but they have run out of them at present and I think the look is too modern for what I want to achieve!
In fact my very first bike a 4 speed D10 Bantam, had quite good brakes on it too!
Being a "Special" you can explore options that other people may not and this is my beef about the Restoration movement per se, it can lead to little if any inventiveness or improvement particularly in the cycle part arena!
I am always cautious riding in the wet and always wear a substantial pair of boots. Perhap,s I should invest in a pair of hob-nailed ones to aid to stopping if anyone still makes them in our sacred Isles!
John H
