Hi Folks
So on my 1976 MK3 with the left hand gear shift, I have a problem finding neutral when I want to switch the engine off or at lights , then as I turn the ignition switch off on the last turn of the engine then gearbox clicks back into first gear so I have to go through the whole process of finding neutral again, which it doesn't like doing also the clutch bites very quickly as I release the lever, I did think it was a badly adjusted clutch cable but seems likely its something to do with the neutral selector, I have recently got the bike back on the road after I found it in the back of a (dry) garage where it had been for over 20 years
many thanks MJC
Check that the neutral swi…
Martin Agreed it could be…
Martin
Agreed it could be a gearbox problem but I'd start by making sure that the clutch is in top nick.
Replacing the clutch centre - which had become worn with ridged splines - and two bent plain steel clutch plates solved neutral selection problems on my bike. I checked all the clutch plates for flatness on a piece of plate glass from my local recycling centre.
Worth a try?
Andy
Thanks guys, I will look i…
Thanks guys, I will look into both those options, funnily enough when I rode to the workshop this morning I switched the bike off using the kill switch and it didn't jump into gear.
Check that the neutral switch is not screwed too far in and stopping the campsite from moving cleanly.
