I fitted a £20 Chinese one to my ES2. It takes its pulses from a cable wrapped round the HT lead. I've set it correctly (1 spark / 2 strokes) but it is a bit erratic especially on acceleration where it consistently locks out at 6000rpm (hahaha). I've set the max revs as 4800 (on the tacho - the book max for the ES2 is 5200) as I don't want to blow the engine apart on a 63 year old bike. Could it be that's it's just cheap junk (pardon the pun) or does something happen to the spark production at higher revs that causes more pulses? Any electrical wizards out there?
George
Hi George, Is it a mag or…
Thanks Steve. It's mag, n…
Thanks Steve.
It's mag, no suppressor. I'll have a look at your quiz and theory bits and see how I get on.
George
Hi George, I bought one la…
Hi George,
I bought one last year from Hong Kong for £4.67 on ebay and was very surprised how quickly it arrived. There was no wiring to do except for winding one lead around the HT lead, so maybe it's the same unit where you just select the correct buttons?
I found that in practice and on the road, I couldn't read it properly as the digits change so quickly that it was almost impossible to apply a rev limit and it's so unlike a tach with a pointer. Anyway, after riding through a tropical rainstorm of biblical proportions for about 30 mins (south east UK) the tach went haywire and was consigned the bin.
Attachments tach-jpg- Log in to post comments
Hi George On a Honda class…
Hi George
On a Honda classic racer, I have a Scitsu Tach. These are not cheap, but common on classic racers. Had some initial problems finding correct length of of pickup wire taped along spark plug wires. When I changed from half to full fairing, the tacho went beserk. Reason was that the pickup lead was too close to one ignition coil. Moving the lead some 4" away solved the problem. Had a problem with tacho on one race, borrowed one Chinese cheap one, worked perfect. As Steve hinted a resistor cap might solve the problem.
Good luck
Thanks guys. I don't have…
Thanks guys. I don't have a coil (magdyno) but I could try moving the wire nearer the lpug (away from the mag) and see what happens. I'm having much the same prob that Bob was having - numbers jumping about.
George
Hi George,
Is it a mag or coil ignition? Plug caps suppressed?
Its possible the sensor (suggest it maybe some Hall effect device) could be picking up noise and translating that into psudo RPM.
HT is a difficult area and the pulse / wave forms can be erratic & noisy; for £20 squid, I doubt if this unit has professional digital filtering to clean up the signal:
Have a squiz here for some simple theory and good graphs:
https://www.picoauto.com/library/automotive-guided-tests/moto-primary-voltage/
https://www.princeton.edu/ssp/tiger_cub/library/ignition_waveforms.pdf
There was also some good theory and waveform analysis (and data) here:
http://www.brightsparkmagnetos.com/faqs/FAQs%20about%20magnetos%20generally/Are%20suppressors%20and%20resistor%20sparking%20plugs%20OK%20to%20use%20with%20magnetos.htm
High voltage engineering is not my area, but someone else may have an answer.
Good luck and see how you go
Rgds
Steve
