I have a query about the original design of the air filter for my 1960 Domini 99. When I got the bike the connection between the carb and the air box was missing and the guy I got it off, my daughters partner, could not remember it ever being connected. After looking through numerous parts web sites I'm struggling to find exactly just what should be in the air box. I'm torn between getting an OEM pancake or cone type but neither will fit in the gap between the carb and the air box. Has anyone come across this or have any suggestions?
I would prefer to have some kind of air filter as the idea of general atmospheric detritus being ingested through the carb does not appeal one bit, plus, it will probably help with tuning the carb.
Hello John .dont know if t…
I have one like that in my…
I have one like that in my box of bits. No use with twin carbs. I think I was told by PO that the filter element was a standard Mini one cut in half.
With the angled inlet I wo…
With the angled inlet I would think that the filter shown is for a single.
Previously Barry Carson wr…
Previously Barry Carson wrote:
Hello John .dont know if this will help you in some way.
Baz
Hi Barry, thanks for the link, I'll chase it up
John
Previously David Cooper wr…
Hi David, as my Dommi is a single carb model it might be just the job.
Thanks for the reply
John
John.. I'll try to find m…
John.. I'll try to find mine tomorrow (if its wet) and post a photo. It is similar to the one Barry posted. It had an alloy sleeve screwed onto the carb (where a bellmouth might go) and it plugged into that.
Hi David; Many thanks I'll look forward to seeing the photo
John
Here it is John. Somewhere…
Here it is John. Somewhere in the shed is an alloy sleeve about 2" long to screw onto the carb and this box was hung onto that
David
Attachments 20161016_154441-jpg- Log in to post comments
The PO was a good mechanic…
The PO was a good mechanical person and it's quite posible that he made it from thin galvanised sheet steel. And made the fancy sstainless steel sleeve bolts.
Attachments 1476629440474-jpg- Log in to post comments
Hi David, thanks for the photos, I'll have to have a chat with a local tin basher who I think can knock up something similar.
Best regards
John
Just in case it isn't cle…
Just in case it isn't clear... the one I have is a single flat disc with turned down edges. The tube is brazed in. Changing the filter needs it to be sprung apart. If I were making it I'd work out the size in cardboard after first gettin hold of the filter element.
Thanks for that David. Just as an aside, the previous owner, (my daughters partner) thinks that there may be one in hismothers garage. There are loads of bits and pieces in there from various bikes including Nortons. if he gets the chance he's going to have a look. As we will be visiting them in the near future, I'm going to take up his offer to have a rummage about in there too, from memory it's an Aladin's Cave of 'stuff'.
John
http://en.vintage-motorcycle.com/index.php?language=en&site=4&pid=38&id=25930&suchtext=%20air%20filter&limit=60
Baz
