Hi.. does the oil-feed-INLET- pipe- from the oil-tank-go to the top or bottom ON THE CRANKCASE- 1949-ENGINE.
The upper connection is th…
Previously George Phillips…
Previously George Phillips wrote:
The upper connection is the delivery from the oil tank and the lower is the return to the oil tank, Tom, George
thanks George.. got her started and working well.. tommy
Lucky you! My '55 ES2 is…
Lucky you! My '55 ES2 is still awaiting the magneto so's I can finally re-assemble it all. George
