Clutch adjustment problem
Really struggling to release the lock nut on the clutch adjuster screw even with the chain case outer removed!
Any suggestions welcomed.
TIA
Usually a sharp tap on a long tee bar and a good fitting  1/2" drive socket  will work when a steady pressure fails . put the box in top gear and a spanner on the rear   brake drum lever nut ( you do have three hands dont you !!.)
