My 1951 ES2 used a huge amount of oil on the trip to Rimini for the International Rally. It smokes a lot at start up and tick over and there's a cloud of smoke as I pull away up the road but it quickly clears and there isn't much at all once I'm on the go. I've taken the barrel and head off and there is no evidence of it blowing past the rings, but the rocker box is swimming in oil and there is a noticeable amount sitting in the inlet port. The valve and guide where both new earlier this year and are in good condition but there are no seals in there and I wonder if there is just too much oil being pumped up there. Given that the earlier engines relied on mist past the pushrod tubes is there any reason why I couldn't restrict the flow going up there slightly. Has anyone tried this before?Or fitted valve stem seals?
I've been reading lots of the other posts on this forum about engine oil consumption and especially crankcase breathing, I think I can also improve quite a lot on that, hopefully lower crankcase pressure will allow the oil that is in the rocker box to drain back down easier and therefor there might not be as much siting up the top.
What have people found in the past? And what solutions did you find?
Any and all suggestions welcome
Andy
mine used half a tank of o…
mine used half a tank of oil in 50 miles of running. James bond would have been proud of me with the smoke screen i was making. anyway i found out mine was oval bore so i had liner and piston done to make standard. that was after having the head completely done convinced that was it but it proved to be the bore out of shape.
before i had it done i stripped it down and bolted the barrel down without the head fitted and kicked the engine over for about 20 kicks and observed oil being left at the top of the bore so something to observe . Baz
Interesting Barry, Mine ha…
Interesting Barry, Mine has been rebored so should be ok, but hasn't been run in yet and I was also running 20/50 and am going to try straight 50 first.n
Thanks for the replies, mi…
Thanks for the replies, mine has a fairly recent rebore and new piston/rings so that should be OK, but I will have a measure up and check ring gaps just to be safe. The oil sitting in the inlet port also points to this being the main point of entry.
If I fit seals I'd have to take the guide out, put it in the lathe and turn the top to take a seal, something I'd like to avoid as I don't have valve seat cutters for when the guide goes back in. I'm tempted by a rubber o-ring to limit what is running down the guide, has anybody actually tried it?
It begs the question, why…
It begs the question, why is there an unusual amount of oil to the top end. Is the return back to the tank partially blocked?
I don't think so - it loo…
I don't think so - it looks to be flowing freely back into the tank when you look through the filler cap, and after a run I drained the sump and there was about the right amount in there. First sign of a restricted return isusually excess oilin the sump.
I have read somewhere about different banjo bolts being use to restrict the flow but it was some time ago and I can't find it now.
I seem to remember the use…
I seem to remember the use of a length of carburettor needle or similar diameter wire down the centre of the banjo bolt to restrict flow.
What volume of oil do you drain off Andy? I have a tap on the feed line, so nothing should get by the pump, and when cold checked how much was in the crankcase. whilst I can not remember the exact amount it was enough to dip the flywheels which, to me, explains some smoke on start up from cold. John
Previously Andy Marks wrot…
Andy.
check that the two oil holes in the barrel are not blocked.
the oil holes in the head have to line up with the holes i the barrel.
i once had a barrel that was able to slightly move on the crankcases so the holes didn,t line up.spopping oil returning to crankcases.
check its all lined up before tightening head down.
tony
Hello Andy. just a thought…
Hello Andy. just a thought if your is the same of course. on the rocker box if the inner sealing washer is not a tight fit in the Centre on the securing bolt it would bypass oil into the rockers
Baz
Attachments oil-return-jpg1-jpgI think you've got it Bar…
I think you've got it Barry. Obvious when someone points it out! Are they meant to be fibre or copper washers?
I've got a few other jobs I want to get done before it goes back on the road so it will be a while before I can try it but that looks likely.
I drained about 80-90ml out the sump, I think the book says a small teacup or something so I think I'm ok on that front.
Thanks again, any other ideas of what I can check would be great as I might as well do everything while it's apart.
Andy
i know mine are copper one…
i know mine are copper ones i never seem to have much success with fibre washers i have used aluminum ones before now quite good at sealing just got to get the right ones not to thick you want some with a bit of squashability. Baz
Hi Barry. With respect I a…
Hi Barry. With respect I am struggling to see where the problem is with your drawing. Irrespective of the size of the washers, if the banjo bolt is tight the oil must go to the rockers. John
The way I see it on that d…
The way I see it on that drawing is the two holes in the side of the bolt are used to restrict the flow to the rockers, so if the inner washer isn't a tight fit there will be far less of a restriction as the oil can also flow between this washer and the bolt to get from the banjo to the rockers instead of going in through the hole on one side of the washer and out the hole on the other. This would result in a higher flow and more oil in the rocker box, which I think is where my main problem is.
I'm sure Barry will correct me if I'vemisinterpreted his drawing.
Yes your right. I went int…
Yes your right. I went into the garage and took mine off to have a look. There is certainly plenty of oil in my rocker box and I have the correct size fibre washers on the banjo bolt. Those two oil drain holes in the barrel are easily blocked if 'gasket goo' is used on the head gasket. John
Hello Andy - John. spot on…
Hello Andy - John. spot on you have got what i was on about. sorry i didn't explained it better all my effort went into trying to upload the right size photo . Baz
Mine smokes a bit too, and was wondering about fitting some seals, perhaps just an o ring to reduce the oil running down the valve stem? I saw that an old bike/car of mine but can't remember which. Trouble is the shape of the valve guide doesn't really lend itself to fitting a seal?
