Anna, it's all well and g…
Anna's lathe method is pe…
Anna's lathe method is perfectly OK. The armature is constructed in 3 separate pieces...Two ends cast in brass with cast in steel bearing spindles and the laminated steel centre section that the coils are wound on to.
The 3 pieces are located with tiny pins and pulled together with two set screws. It is easy for someone to reassemble them badly and sometimes different pieces are used if something has been damaged (spindle broken for example). After reassembly, it is often the case that the armature is not perfectly true and runs with a slight wobble, so it is fairly common practice for the complete armature to be set up in a lathe and skimmed, although the clearance to the magnet must not exceed 1 thou ( I think) as the concentration of flux through the armature is considerably reduced. Anna seems to saying it is just one small part of the magnet that is out and rubbing which is also a possibilty...not sure if she has skimmed the armature yet though?
Les
Personally, I would only e…
Personally, I would only entrust a magneto to a specialist, not to a marine engineer, or self taught "Expert" Possibly you can get a "Free lunch", but very rarely.
My "free lunch" has cost m…
Ooops! Nearly forgot. Plus…
Previously John Shorter wr…
Hello well the expert will be its owner he has more engineering qualifications after his name than me, So George should be well capable of sorting his own magneto me I not that well these days but try to keep going and money is very tight now only working 25 hours a week and that enough for me to be exhausted, for the rest of the week, at why I will not be renewing my membership has I cannot afford it just yet I lots to do and no one to help so there is only me to sort things But hey you guys have a nice time this Sundayat your AGM yours Anna jPersonally, I would only entrust a magneto to a specialist, not to a marine engineer, or self taught "Expert" Possibly you can get a "Free lunch", but very rarely.
Well Anna, I can help with…
Well Anna, I can help with the money part, I have been emailing you to get an address so I can send you 15GBP for the partsbook coppies, but I have gotten no reply. I have 3 English five Pound notes left from my UK visit last summer, no good to me here, I just need to know where to send it.
Skip
Previously Skip Brolund wr…
Hello Skip Sorrymate that you had a hard time getting in contact with me Now today I will go to Goole library and have this parts manual copiedfor you I live some 7 miles from Goole and with working around here, I only get a chance to get to Goolenow and then, its remote countryside here nothing but farmland and trees for miles I will send you my address by Email OK I just getting old and worn-out and forgetful so hang in there you get this part manual in the end yours Anna JWell Anna, I can help with the money part, I have been emailing you to get an address so I can send you 15GBP for the partsbook coppies, but I have gotten no reply. I have 3 English five Pound notes left from my UK visit last summer, no good to me here, I just need to know where to send it.
Skip
Almost at the end of this…
By the way - to all those…
Just to tidy up this post…
Well done George. Please k…
Well done George. Please keep us posted as to whether the new bush reduces (or even eliminates) the oil flow into the mag chain case. If it does that is the next job for the 19S. I'm sure I've mentioned this before but the inner steel strip from an old wiper blade is thin enough to go into the plug hole vertically, so no need for the 45? correction. Equally important it is long enough not to get lost in there if you let go.
Cheers, Ian McD
Thanks Ian. I'll check th…
Just for fun, Ian, I did a…
Looks vertical to me - dfr…
Looks vertical to me - dfr (do fine rightly)! And there are some handy casting lines on the head to serve as a datum. Just to stir the muddy waters some more do we know for sure that the plug goes in at 45?? Enjoy your run tomorrow.
Cheers, Ian McD
Gentlemen, may I recommend…
Gentlemen, may I recommend the purchase of a 16H ? They have a central plug above the piston and no valves to tangle.
I can however confirm that if one lets go of the carefully marked IKEA pencil on the downstroke, it will disappear and be crushed to smithereens before one can say 'Edgar Franks' !
Take it off and do it again !
Ian - you've spotted the…
Bad news George - I measur…
Bad news George - I measured the plug angle last night, 50? from horizontal. But I don't think you will be re-timing for that!
Cheers, Ian
Previously George Phillips…
Almost at the end of this long running saga! Collected the mag from Brian Winter-Baker. New body fitted as the one I handed over had the inner end plate that holds the inner bearing broken off. He'd had it running on his test bed which I witnessed and it was sparking like a good 'un. Total cost £45 so very impressed. For those following this thread the original problems with re-assembly were 1) I hadn't tapped the Woodruff keys in far enough(they were very much an interference fit) and 2) one of the bearings was not in true causing the armature to be spinning slightly off centre hence hitting the magnets. Once trued up it all span proper! Hope to get it back on tomorrow and who knows - I may have the bike on the road buy Easter. Yippee! George PS My grateful thanks to all who contributed to this exceptionally long-running saga. I hope we've all learned something from it. I certainly have!Hello yes becausethe woodruffkey was too fat I filed it up so it would fit right and the threads for the end nut has they been damaged the housing was not one of the best it had damage on it too and a brass shim was missing yours anna j
Previously Ian MacDougall…
Hello Never ever use anything metal down a plug hole its damages the top of the piston with small scratches, please use a long artist type paint brush handle end its made of wood and rounded off too then you can simplymark anywhere you like for top dead centre and the like yours anna jWell done George. Please keep us posted as to whether the new bush reduces (or even eliminates) the oil flow into the mag chain case. If it does that is the next job for the 19S. I'm sure I've mentioned this before but the inner steel strip from an old wiper blade is thin enough to go into the plug hole vertically, so no need for the 45? correction. Equally important it is long enough not to get lost in there if you let go.
Cheers, Ian McD
Sorry for the delay, Ian.…
SEE the FBHVC website Etha…
SEE the FBHVC website Ethanolfuels! Goerge ! yours Anna J
Righjt! All back together…
Anna, it's all well and good you stating the above but if we look to your earlier post, you were going to grind the body out to create clearance for an out of true armature. So maybe you can understand why certain reservations have been made.
Is a bit of a mess new armature that'sout of round by 0.005 thou which is just enough to catch in inside the body and make a contact shorting out the magneto process, So the only way I can think of is taking out about 0.005 thou out of the body the magnet fits to one side and its only magnetised steel I am grinding out bit at a time and very carefully to making measurements in-between times on my mill drill I use a fine set of stones from this process . has you cannot take anything off the armature you disturbed the windings inside
