Hi
Looking from the points end off a magneto on a dominator which plug lead goes to which side
The usual way of working t…
The usual way of working this out is to pound the kickstart fruitlessly for 10 minutes and then swap the plug leads over and be amazed when the bike starts first kick.
Previously Gordon Johnston…
That only tells you the way things actually are, not the way things ought to be.
I've never actually notic…
I've never actually noticed it written where each plug lead ought to go. I don't think I would worry as long as the bike actually ran. I'm happy to be a pragmatist. There's a lot to be said for single cylinder engnes.
The one furthest away from the crankcase (right) goes to the left side plug. This is stamped "1" on a BTH magneto, no marking on a Lucas.
