My 1960 Slimline 99SS has a SLS front brake and Doherty handlebar levers. Both levers are worn and need replacing.
The clutch-lever (adjustable) measures 1" 1/16 between pivot and nipple centre.
The brake-lever (non-adjustable) measures 7/8" between pivot and nipple centre.
The brake-lever is upside-down. Front brake performance is a bit poor but shoes are nearly new and getting better with miles. I have good clutch action.
I have read through numerous letters here on NOC, but there appears to some conflicting views.
Some say both should be 7/8" pivot levers. Surely a larger pivot distance would apply more pressure on the front brake and easier clutch operation.
What would have been fitted as original at the factory?
As a Dominator newbie can anyone please help?
Sincerely
Bert Powell
Hi Bert, My 1957 99 has th…
My 1960 99 std untill rece…
My 1960 99 std untill recently had the orriginal levers both non adjustable. The clutch is 7/8th cc which is correct for the AMC box. I had always assumed the brake to be the same but was surprised to find it to be 1 1/16, It is definately orriginal and features the choke mounted on top with the curious extended nut underneath. I have used a 7/8th lever for the brake and find it to give a better action but needing regular adjustment and a good solid cable. I own bikes with SLS and TLS Norton brakes and find that providing I ensure the leading shoe is always the thicker of the two then the SLS brake is as good as the TLS but being less fussy on set up and a bonus is that it will also stop in reverse.Which the TLS will not. What was fitted to the SS models I can't be sure although ball ended levers were common on them.
Previously robert_tuck wro…
hello original leavers were AMAL As I have the Amal Leaver manual yours anna j
For the AMC gearbox, Norto…
For the AMC gearbox, Norton fitted 7/8" clutch levers. The clutch lifter profile on the AMC box is too sharp, so gives lots of lift but is heavy. Using a 1 1/8" lever will make the clutch very heavy indeed.
Previously paul_standeven…
hello there is a reason why the clutch is heavy you have the wrong clutch springs that are way too strong try getting a set of lighter springs but with the same bite, and the clutch cable end at the gearbox end should have a small ball end and not a nipple barrel end like you get from the after market , its these people that are making parts that are incorrect parts that are not doing the job in the correct way ,So by getting the right cable and the right type of springs for your clutch will make your life and riding that much better yours anna j
Anna raises a good point a…
Anna raises a good point about incorrect parts. Just because the part has been supplied by a business that professes to know about Nortons does not mean the parts will work on your bike. Clutch springs are a case in point and to tell the diference between right and wrong you will need at the very minimumm a micrometer to measure the wire diameter ,Which will be a good indicator. You will also need the correct free length and some way of measuring the quality of the spring action. Hard springs are not the answer. Room here for an informative technical article.
Many Thanks for all the re…
Many Thanks for all the responses.
Really appreciate you all trying to help me out!
My bike, the one in question here; is a 1960 99SS with 48,000 miles on the clock. I am only the second registered keeper since it was first registered in Feb 1961. It is in very original and unrestored condition. I am trying to retain as much of its originality as possible.
The handlebar levers, and throttle are all marked Doherty items and all appear original as do the rubber grips which have a diamond pattern.
I think the actual lever blades may have been mixed-up as the clutch lever has 1"+1/16 pivot points although it is a left-handed blade. The brake lever has 7/8" pivot points and the blade is upside-down and therefore a left-hand item.
New clutch-plates and springs have just been fitted and the clutch works well, even with the 1"+1/16 pivot point blade.
Anna states above that Amal levers were fitted as original equipment.
At this stage I am just trying to establish the correct parts when it left the factory.
Could Doherty levers and throttles also have been used?
I expect someone swapped t…
I expect someone swapped the levers over thinking that the bigger CC would give a bit more travel for a draggy clutch.
Previously Bert Powell wro…
Hello Doherty are Aftermarket goodies or baddies witch ever way you look at it I can give the Amal part numbers if this helps Amal clutch leaver for models 88 and 99 are part number 18/556 and combination leaver for air and the front brake are part number 18/732 and twist grip is part number 16/417, and there pain end leavers NOT ball end leavers with NO adjusters on the leavers Now hope this may help and shed some light on things And one other thing is the Model 99SS was Not produced until 20th of april 1961 So what machine you may have I have not a clue but if its 1960 built then its Not a 99SS as the (99SS) wares the Norton Manxman 650 engine cases and cam shafts and follower and push rods fat type the same as the 650s have As just happen to own a december 1960 built Norton Manxman 650 an export only motorcycle there are only 10 with in this country, yours anna J
Hello Anna, Thank you for…
Hello Anna,
Thank you for your reply. My mistake, I must bow to your superior knowledge.
It would appear then that I must therefore have a 99 that has been brought some way towards having SS spec.
The engine / frame numbers seem to indicate it was built in the last quarter of 1960, and the V5 shows that it was first registered in Feb 1961, and that I am apparently its second keeper.
I did say in the first place that I am a Norton newbie; even though I have been motorcycling continuously for 47 years. Anyway, hey ho; nobody knows everything.
I will continue to try to find out exactly what I have with my machine and perhaps just may invest in a search of the Club's factory records.
Thank you for your time and most helpful information.
Kind Regards
Bert Powell
gr010026jpg_crop_2-jpg
Thats a cracker!, Gen SS o…
Thats a cracker!, Gen SS or not someone has built a very good looking bike. The colour scheme mimics the later SS bikes from around 62, the early 88/99 SS bikes used the same colour schemes as the std bikes. Usually the SS was marked on the crankcase. I would set the Kickstart back a couple of splines as it will interfere with your boot as it is.The speedo drive is set at a steep angle ,possibly a longer than necessary drive cable has been used. The cable run along the lower frame was correct at that time ,later AMC bikes did it differently. The siamese pipes (with a very nice line) are RGM I think.Love that twin Mono carb set up. Throttle cable looks too long, probably worked fine with the normal std low rise bars. The cylinder head is from an earlier bike say 56/7. Usually giving a slightly lower CR (depending on pistons fitted) and smaller valves. probably a good thing if you want the motor to last.
hello nice looking motorcy…
hello nice looking motorcycle but far from factory standard colour is the wrong and colour of the seat is wrong the model (99) standard were in Norton Grey and Dove Grey and seats were in two tone grey and Chrome mudguards where only available at Norton Bracebridge street out let shop has the standard model had dove grey painted mudguards the twin carburetor set up was first fitted to the clubman model 88 and then model 99 1958/60. So now it looks more like a Plumstead 650ss then a bracebridge street beauty with all the 1960 nice colours they did of that era Not all Norton,s were black and silver from 1958 some where nice post office red or forest green or light metalescent blue now early 1950s and 60s Norton's are getting rare in there standard factory colours all very nice smart motorcycle witch would make any owner very proud to own, and a joy to ride, But anyway its your nice model 99 so enjoy your motorcycle and look after it they not make these no more, that's for shure, Well I am sorry to say I am stuck in the Era of 1945 to late 1962, all Bracebridge Street Norton Motorcycles after this it went pare shaped for me, And 45 years owning Norton Motorcycles and enjoyed every minute and I am hoping there is still a bit more to come, As i love these machines, and I can look at them allday there a work of art and a motorcycle rolled into one So if you need any more help I am not far away yours Anna J Dixon
Thanks for everybody's co…
Thanks for everybody's comments. I am really enjoying my Norton 99. Another interest of mine is genealogy and that probably explains why I am trying to research my bike's DNA.
As I said I have had bikes continually for 47 years, but never had a Norton until now. I have ridden a few Nortons over the years but they were a Norton Interpol, and a Norton Rotary, also painted in white and with red stripes! One of the first bikes I owned was a Triumph TR6R Tiger on which I did over 68,000 miles in less tha 4 years. I then had a few Italian bikes including a couple of Laverda triples and also a Ducati Hailwood Rep. I then raced a couple of Ducati singles including a rather lovely Saxon Ducati 350 which had an absolutely marvellous handling frame.
I always tended to shy away from Nortons as my father met his end on one a month before I was born. Even so I have always had a hankering for a bike with a featherbed frame. When this one came up, I thought that as it had been in one family all its life, it was a survivor and was a one-time only opportunity. So there we are.
I think possibly the original owner always wanted an SS but probably couldn't afford one in the day. The chrome mudguards and seat are genuine Norton items so that is good. The tank is admittedly not quite the right colour. It is quite a headache knowing what I should do with her as she is so honest. At present I am shying away from total restoration and just taking my time and deciding what to do and how far I will go. The alloy rims are nice, but have no markings. The electrics are still 6 volt alternator. The front brake is a bit lacking and I may well go with a 2LS brake-plate for todays traffic conditions. I am not in the least bothered that she is non-standard. In fact, years ago, when I bought my Laverda SFC1000 new, of the other four in the showroom, not one was exactly the same.
Doesn't matter to me that the 99 is not 100% perfectly concours accurate, 99 will do! (Haha, just thought of that.)
Bert Powell
Many of us converted our s…
Many of us converted our standard 99s to look like 650ss models. All the rage when I was a lad. Mine started out as a red and white DeLuxe but now looks like a scruffier version of yours.
Accept that the changes are all part of its history and enjoy your rather splendid looking machine.
Couldn't be absolutely sure, but is that a 1959 cylinder head on yours? Is there ribbing between the rocker spindle covers?
The 90 degree fin below th…
The 90 degree fin below the exhaust rocker plate is the giveaway Gordon. Earlier head or not its a nice mixture.
Previously Gordon Johnston…
Thanks Gordon,
I think it might be. Don't know what valves are inside it, but it feels quite high compression. Must do compression test.
The top of the head casting has the numbers T2225T
gr010032_2-jpg
Thanks Robert!
Hi Bert,
My 1957 99 has the 1" centres on the clutch and 7/8" centres on the brake.
The 7/8" centres give a better mechanical advantage and therefore more cable pull and better braking.
The 1" clutch increases the force required but gives more cable travel reducing the chance of clutch drag.
Hope this helps.
Dick
