000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
Sump drain bolt
Hi everyone, a naive question as per title.
I have a 1948 model 18 and I am  unsure where the sump bolt is  as it is wet dumping if left for more than a week,  I can only see one bolt head 9/16 I believe  but it is so tight  that I don't want to do any damage, if it's the wrong one, hopefully  someone can point me in the right direction. Thanks in advance .Paul
Hi Paul,
   The sump plug on the 1948 (one piece rocker-box) engine is underneath the crankcases in a partial recess, so it's best to use a Whitworth sized socket to remove it. The plug is 3/8" Cycle thread which is too fine in aluminium and easy to strip the thread if over-tightened. This will mean you will have to address the wet-sumping, because continual draining will soon damage the thread in the crankcase. You might have to consider a tap or one-way valve on the oil feed.
... has been changed by a previous owner to a metric coarse thread which is better. I'm not about to strip the whole lot to replace something that works well enough......
Privacy Policy
