000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
1953 ES2 dualseat
I'm restoring a 1953 ES2 and have a (BMS) copy of the 1950 Norton parts list, together with the supplements for 1951 - 1954. I can't find any mention of the dualseat introduced in 1953 (or even the 1954 dualseat). The dualseat fitted on the bike is mounted quite differently to that on a friend's 1957 19S.
We're wondering if the ES2's seat and its mounting points are original or a later modification / addition.
Can anyone advise?
Front mount
Rear mount
Seat's undersideCheers, Simon.
I've been through this a bit with my 54. Project ongoing and still haven't solved it. Those parts including the seat look suspiciously like  1955 parts. 53-54 I thought had a U-shaped bracket bolted to the seat base that registered with the shock absorber top mounting bolts. Tge front bracket also had a section at the bottom that rested on the frame as well.
Chris
Here are a couple of pics of what i believe is an original 53-54 seat pan ( a bit worse for wear) plus a front bracket taken from a very original 53. much the same as what you have except fot the downward facing tongue that rests on the frame.
Chris
Simon. Yours looks the same as my '55 ES2 seat. I have always thought the front mounting was a little crude and over engineered but it works. I ride two up quite a lot and didn't think the rear mounting provided enough support so made a couple of extra brackets that mount to the top shock mount. Probably not needed though.
Ian
In reply to by ian_goodhall
simon  your frame and mudguard fittings are the same as my 19r 1956. Also the seat with the threaded holes is the same.
Hi all. I have two ES2s -- a 1953 and a 1954. I've had them both over 10 years and I'm still working on determining what's "correct" given the lack of parts drawings for these years.
Anyway while this is not absolute proof, I think both my bikes have the same seat pan, which means they may be the original factory piece. It's similar to Simon's pan but not exactly the same. I have not had the 1954 seat off yet, but it appears to match and the brackets look factory to me. I only have a photo of the poor-condition 1953 one because it's off the bike (I circled the mount points that are actually used in the other photos):
Possible original 53-54 seat pan showing mount points
Note the pan is mangled and the mounting bracket shown at bottom is NOT correct - the original mudguard was missing from the bike this came on and the mounting was cobbled up.
Now some shots of the 1954 seat (still on the bike). This pan appears to be mint and the seat's been nicely recovered. Note a U-shaped bracket connects the front three lugs on the seat pan to the front frame lug (no contraption as shown in Simon's first photo). I tried to circle the three bolts corresponding to the lugs on the seat pan:
Underside of 54 seat pan showing rear mount bracket attached to mudguard
Now the rear is mounted with the same REAR bracket as Simon's seat (only half is visible in this photo):
I would appreciate everyone's input - do I have the real 53-54 seat pan and brackets here or possibly two later replacements? Or a mix?
I could really be wrong -- Chris' info seems plausible to me too (but doesn't match what I have here). The front lugs on my pan might fit a bar that picks up the shock mounts, for example.
Thanks and cheers!
Andrew
I am a building an ES2 bitsa at the moment, the frame is 1953 as it the tank, so I have been looking for seat. This subject seems to cause much debate, the Norton adverts at the time, and Leightons confirm that the 53 seat was flat in profile, not dipped like the 55 seat, (Not sure about the 54).
after some discussions with Leightons they are going to have a few bases made so they can make up a small run of seats. I’m having one, if anyone else wants one best get onto them pronto, however it won’t be cheap - approx £300.
What I don’t know is if the bracketry is the same as the later style seat. This is the report from the motorcycle at the time of the launch of the 53 model.
Dan
1953
Hi Simon,
   Fairly sure your dual seat is a BSA , perhaps B33, A10 etc. Might be worth looking on the web to see if you can find one similar to check.
Privacy Policy
