I've got a couple of Domonatoroil pumps and would like them serviced, is there anyone in the UK who does this at a reasonable cost?
I could do the flat services myself, but as the cost of re-building an engine is considerable I'd like to be sure that they are good.
Thanks Keith
Previously Phil Hannam wro…
Previously Phil Hannam wrote:
Have a go yourself. If you have several similar pumps then you may be able to mix and match the best parts. For a DIY guide on servicing these chunks...........Go to theRoadholderpages of this site, navigate through the archive toRh 327, February 2015.
Plan B...........ask Dale Middlehurst .........who used to offer a refurbishing service.
Thanks Phil
Perhaps I'll have ago and see how good I can get one.
Keith
RGM Motors do a Norton oil…
RGM Motors do a Norton oil pump reconditoning service so you called either call them or send them an email. Their tele number is 01946 841517, or email them.
I'll send one to RGM and…
I'll send one to RGM and see how it comes back.
This should be interesting…
This should be interesting??? How will you know what has been done? Will they provide before and after photos and flow tests results? I would hope so as otherwise you might be waving goodbye to £45 plus and not gaining much for it.
