Model 18 primary chain lubrication
Will the primary chain on a 1938 model 18 get enough lubrication from the oil mist coming from the crankcase via the drive end without any oil in the chain case ?
I would say no. A lot will depend on how its used. If you intend to go this route I would suggest that you spray the chain with a proper foaming chain grease (not wax)  before use and if going any distance carry a can . You could fit a chain oiler and accept that things will be mrssy..
Thanks for your advice Robert. I’ll try and keep some oil in the chain case. I’ve been reading the many threads on this subject on this site. So fingers crossed
