Hi, I need to clean out the threads in my 72 750 cylinder barrel, the ones for the 4 bolts beside the spark plugs and the one front centre. Can anyone tell me what the threads are so I can buy a set of taps. Cheers. Billy.
If you just want to clean…
Hello there William The bo…
Hello there William
The bolts are part nos. 06.0401 (4 long ones) and 06.7918 (single short one).
I've checked this reference:
http://www.rgmnorton.co.uk/csi/1245184/f/pdf/cylinder_head_kit_notes.pdf
And this one http://stainlessbits.com/link12a.html for 06-0401
The bolts are 3/8" x 26tpi CEI or BSC (BSCy) threads.
Hope this helps
Andy
Previously Andrew Heathwoo…
Previously Andrew Heathwood wrote:
â?The bolts are 3/8" x 26tpi CEI or BSC (BSCy) threadsâ?
You're rigth Andy, I'm sorry.
Fritz
Hey Fritz No problem. It i…
Hey Fritz
No problem. It is just a bit frustrating that this information is out there but doesn't seem to be readily available on the NOC site. Ho hum...
Andy
Hey Fritz
Andy
It isn't already on the net. I.e. Icouldn't find it with ?Google?.
Fritz
If you just want to clean out threads file a v into an old bolt turning it into a chasser. You can then clean out the threads with it without removing any material. You can then fit new bolts.
