Could someone please recommend someone to balance 650 twin crank.
Many thanks Jim
Crank balancing
Big end shells for 650 twin
As Ive had the crank reground -10, I looked on the spares page & was disappointed not to find +10 shells, would anyone be able to tell me where I could get them.
Many thanks jim
ps Thanks Anthony for the information.
-10 shells
Forgive me if I’m reading your post incorrectly but -10 refers to the new diameter of your big end journals after regrind (ie now 1.740” rather than 1.750”).
The shells to go with this are also -10 rather than +10 as the internal diameter of the shells is similarly reduced to match the reduction in journal size.
Big end shells
If I am not mistaken, the 650ss crankshaft size is 1.75 so it is the same as the Norton Atlas and the Commando crankshaft. You can see if there are -10 Atlas or Commando big end shells.
A couple of months ago…
A couple of months ago bought 'em from Andover Norton. Same for 650 and Atlas. Mine also had to be reground -.010. Done with correct radius. It's wise to also check that conrod big end isn't oval and need machining. One of my conrod small end was a bit too loose fit, had to be replaced.
crankshaft regrind
Hello well, I had mine done at Arnett engineering Doncaster There was No need to rebalance with - 10 UNDER SIZE NOW CHECK IF YOU OIL PUMP is 3 start or 6 start as if you have a 3 start oil pump there is No NEED for OIL HOLES in the Shells or you have more problems yours anna j
Try Basset Down in Swindon, as they have been doing this for a very long time.
