Just rebuilt a 1959 99. I didn't split the crankcase because I was told that the bottom end had been done.
Fitted new Norvil barrel and pistons, new carb, refurbished magneto, refurbished head and new pipes and silencers. When I first started it (2nd kick)it ticked over beautifully although the exhaust note sounded very blatty and after an initial run of 20 miles it was clearly running very flat. So checked ignition timing again and auto advance and valve clearances. I put down the poor performance to a problem with the silencers, so bought another pair but still the same problem.
I am now thinking the cam may be a worn out one, so I intend to change the cam. Can anyone advise if this can be done without splitting the crankcase.
I was wondering if you are…
Simon - the quick answer i…
Simon - the quick answer is no - you must split it.But before you do - you could remove the head and put a dial gauge on top and measure the lift down the push rod holes first to make sure it really is the problem. And before that - if you are very careful it might be possible to check each valve lift approximately using calipers through the inspection covers. It could save a lot of work! You are sure the valve and ignition timing are both spot on? It's difficult to see the timing spots on the cam sprockets properly when the chain is on but Phil posted a useful picture some time ago.Norvil web site has notes on fitting a new cam. They are very insistent about changing the followers at the same time - so that's £300 or more for the whole job. Of course - that advice is in their own interests. Do any experts on this site have strong views or experience of this?
Because the dommys still h…
Because the dommys still have an oil trough they give the cams and followers a much easier time, if in good condition I would lightly stone the followers to give a new surface to the new cam and use the installation cam oil and avoid letting the motor tick over at start up. Never had a problem with cams or followers.
Thanks for all the advice.…
Thanks for all the advice. I will double check the valve chain and the cam lift before I go for the complete crankcase split.
I was wondering if you are one tooth out on the timing chain. If there is one extra tooth length on the top run the the valve timing will be retarded.
I would have imagined that a worn cam would result in a softer quieter exhaust tone.
You can check with a dial gauge directly of the push rod ends to see what the valve lift is, an easy job, not like checking valve timing which is not. If you look on the "Atlantic Green" Norton web site it will list all the valve lift specs.
Total engine strip required to change camshaft!
Check cam followers first IF after finding valve lift shortage, as they might have worn hollow....although with a new barrel these are likely to be new also.
Les
