Take delivery on Monday of my new Dominator. Will do a write up on how its rides etc weather permitting!!!!!
Previously graham_leblond…
How's life with the Dommie big G ?? What about a meet at the cafe near Brands if you're up for breakfast and a thrash. Terry
Previously terry_woods wro…
Sunday morning weather permitting !!!!!!!!
Hi Graham, how easy was it…
Hi Graham, how easy was it to remount your plate? Picking my SS up on Monday or Tuesday and ideally want the stock plate holder/mount gone prior.
http://i2.photobucket.com/albums/y28/iwilson/Norton/image_zpsuctotb0i.jpeg
Attachments image-jpeg- Log in to post comments
Hi Ian Its a simple operat…
Hi Ian
Its a simple operation but you have to work like an obstetrician.
The old bracket is easily removable with just a few allen bolts and screws. However you have to remove the rear seat section to get to the wiring.
There are two retaining screws underneath at the rear of the unit. Under the seat hump you will find an alloy plate with large grommets. Remove these and insert a long allen key (7mm I think) into the void. There are two domed bolts which loosen the unit. It pulls off and you can then split the wiring to be able to change over the indicators and original light.
I did have to call Sean, who I take it has provided the new bracket for you, as there isn't a manual covering the removal of the seat unit. It would have taken me forever to find the domed bolts as there is no vision of them at all. As an asides you will also find the charging lead in one the holes behind the grommet.
Obviously fitting is the opposite but make sure that you put the seat unit back on before attaching the new bracket etc as the two rear retaining screws are covered by the new bracket.
A set of stubby ratchet spanners also make the job easier due to the limited room behind the rear light.
There is no provision for a number plate light and I currently have my lead cable tied up under the seat unit until I decide of what type I want. It will probably be an LED unit which are readily available on eBay.
Any problems send me a pm and I will give you my number.
Good Luck
Graham
Finished article Attachmen…
Finished article
Attachments 2015-12-23-12-32-20-jpg- Log in to post comments
Hmm a bit more to it than…
Hmm a bit more to it than I was hoping. I don't know who Sean is, I'm in New Zealand, perhaps he's someone at the factory?
I had a quick peek and thought I might be able to fashion a bracket to hang of the indicator mounts. But not sure if they'll be strong enough. This issue seems to be a real grey area. I presume what you and everyone else does is illegal otherwise manufacturers wouldn't bother with the expense of fabricating the stock unit in the knowledge it was going to be removed immediately! On the flip side the police don't seem to care unless you mount the plate on a crazy angle.
Hi Ian Sorry didn't reali…
Hi Ian Sorry didn't realise your situation. There is a guy called Sean who will manufacture a new bracket for you but he is based in England. He is very good and the bracket comes powder coated and is of factory quality. I think the regs are such that the horrible OE part is required to meet their criteria. I don't think that the police here are not worried about enforcing this. If you PM me I can send you Sean's details. If not good luck with making one . There are several aftermarket companies that make generic brackets. I am sure one of these will work with a little modification.
I guess that another probl…
I guess that another problem with road legality would be the lack of reflector.
Raphael
Rapahel Is this something…
Rapahel Is this something that is strictly enforced in Switzerland
Yes it is, but I would be…
Yes it is, but I would be surprised if it was not in UK. Otherwise they wouldn't deliver them with reflectors.
As long as you do not have to pass the vehicle inspection here it should not be a problem. In any case you can still tell them you just lost it.
Actually I was driving for a while without one because it did break and got lost...
So no worries to pass through Switzerland on your way to Rimini
Raphael
Thanks for the info. Whils…
Thanks for the info. Whilst it is a requirement I have never been questioned about the lack of a reflector except at MOT time.
Thanks for the info Graham…
Thanks for the info Graham, picking the bike up in a couple of hours now. Will have to suffer the indignation of riding her the 30 miles home with the stock plate holder - there are worse things in life I suppose.
Will take sometime and look at all the options once I have her home.
Reflectors do have their u…
Reflectors do have their uses other than passing MoT tests. I was riding down the A1 if rain and fog and was stopped by a lorrydriver who pointed out that my rear light had failed and it was only the reflector showing up in his lights that stopped a collision. Yes, the lorries were travelling faster than me...
Of course you are right Go…
Of course you are right Gordon. I was once driving with a failed rear light. The bad thing is you normally do not recognise it. It would have been much more uncomfortable without reflector...
Hi Ian Please let me know…
Hi Ian
Please let me know how you get on. I had a look through your photos and for your info the guy who makes the number plate bracket also makes a cover for the throttle body in black or polished. I have attached photos
Attachments img_2527-jpg- Log in to post comments
Thanks Graham, picked her…
Thanks Graham, picked her up yesterday. Have managed 60 miles so far. Wrists and neck not particularly happy but with a few more miles they'll adapt soon enough. Seat is fine could easily do some big miles on it.
Stock pipes and plate holder not as bad as I'd feared in real life. But far to quiet. I wish they'd fitted the short sports pipes - wondering if they weren't available when they signed off on the design. The megaphones apparently are at the other end of the spectrum and pointless to fit if you intend riding regularly. Plus talking to the service tech yesterday they take 3 hours to fit since you have to change the pegs as well!
But still grinning from ear to ear!
Hi Ian Whats that funny gl…
Hi Ian Whats that funny glow in the background? I remember its the sun. The seat does take getting used to but as you rightly say it just takes a few miles for the body to adapt to the riding position etc.
I don't know when you ordered yours but the short pipes only became a choice rather than an additional option late last year. The megaflow pipes look great but I think may attract too much of the wrong type of attention for everyday use. I wasn't aware that a peg change was involved as I did intend to order a set as a spare thinking it would be a simple 30 min job to swap.
Enjoy!
The bike comes with a big…
The bike comes with a big bag of bits, including new brackets for relocating the foot pegs etc. Also a different fuel filler cap. I'll unwrap everything and take a few photos.
I do feel sorry for you, 29C today, it hasn't rained in weeks so we could do with some of your rain!
Here's a picture of the p…
Here's a picture of the packing list.
Attachments imag0033-jpg- Log in to post comments
Hi Ian I saw your thread o…
Hi Ian I saw your thread on Access Norton but had not put it together that you were one and the same. Terry who is also on this site has Rizoma on one bike and Oberon on another. He says the quality of the Rizoma is far better. I have Halcyon mirrors fitted to mine.
Hi Ian What's the differe…
Hi Ian
What's the difference with the fuel filler cap you ordered?
Do you have a picture?
Raphael
Extra one is a locking cap…
Extra one is a locking cap. Can't see how you would fit it without butchering the tank.
Standard
http://i2.photobucket.com/albums/y28/iwilson/Norton/image_zpsgozskptw.jpeg
Locking
http://i2.photobucket.com/albums/y28/iwilson/Norton/image_zpsmnalnql1.jpeg
http://i2.photobucket.com/albums/y28/iwilson/Norton/image_zpsf8zeqf3n.jpeg
Also grabbed the opportunity to get some more k's under my belt and ride back to the dealer to see one fired up with the megaphones. Sounded great just 30db to loud!
https://www.youtube.com/watch?v=UKjTB5DACHw
Ian, it seems you got the…
Ian, it seems you got the standard filler cap of the Commando 961. If I remember right somebody wrote once that it is from BMW...
Previously raphael_vonaesc…
Raphael,
I thought my tank would have the Monza type filler cap as fitted to the first SS, when I asked Nick at the factory why the nasty screw cap he said it was because they had been experiencing problems with the Monza type leaking and it presented a problem with type approval !!!.
Hi Terry I am wondering ho…
Hi Terry
I am wondering how the Monza filler cap looks like. Do you have a picture?
Raphael
Hi Terry
Raphael
Hi, no I don't have a photo just Google it loads on there
Terry
Attached photo show front…
Attached photo show front end of a 7 week old 961 Sport. Same age as yours Graham ........... I did try and email you!
Is this a quality control issue, normal or other?
Attachments 961-front-end-1-jpg- Log in to post comments
Hi Phil, Sorry working lon…
Hi Phil, Sorry working long hours and just picked this up. Are you referring to the surface rust?
Hi Terry
Raphael
Terry
I guess, you mean this one (see attached Link).
Would look good... May be this type of filler cap could be found somewhere to fit to the alloy tank.
I will let you know, if I find something.
Raphael
Attachments norton-dominator-ss-2-jpg- Log in to post comments
Previously Phil Hannam wro…
Hi Phil,
More a cleaning issue unless you have no miles on the bike.
Checked mine out and looks ok but I will remove the spindle and grease anyway thanks for heads up
Terry
Hi Terry
Raphael
Terry
Raphael
Looking at the picture I'm wondering if that Monza cap just screws on to the threaded boss on the Norton tank, I'll ask the factory.
Terry
Hi Terry
Raphael
Terry
Raphael
Raphael have you received the alloy tank yet.
Terry
Can anyone advise on how t…
Can anyone advise on how to re-illuminate the speedo on a 961?
At the back of the speedo are two plug sockets and a hatch. So where are the bulbs/LEDs positioned and how do you change them? There does not appear to be any advice in the Owner's Handbook apart from bulbs are not covered by the warranty.
Attached pics show minor surgery.
Attachments 961%20speedo%20light%20replace%20-%20Hatch.JPG 961-speedo-light-replace-underside-jpg- Log in to post comments
Are you sure the bulb is d…
Are you sure the bulb is damaged?
There is also a function of changing illumination which is not described in the manual. If I remember correctly, you have to switch to the indication of voltage then change strength of illumination by pushing longer on the button...
Just in case, maybe this helps.
Thanks Raphael.......this…
Thanks Raphael.......this could be the answer. The only doubt I have over your suggestion is the rev clock is still shining brightly. Are the two clocks not both dimmed together?
The Owner's Handbook does not appear to much help regarding this procedure or any similar. Perhaps it is written on one of the blank pages. Along with changing the clock, using the trip meter etc. It took me 2 months to work out why 12.1 kept appearing on the little screen.
Well, they are obviously b…
Well, they are obviously both dimmed together. Sorry, then it would be the bulb. I have no clue how to change it, cause never had to...
If you don't grab answer here, you may ask your question to Richard-7 or maybe find it in one of his useful manuals:
http://www.accessnorton.com/961-manuals-t22297.html
Raphael
Phil My advice is to phone…
Phil
My advice is to phone the factory, the service department are always willing to help and advise.
Terry
Hi Terry
Raphael
Terry
Raphael
Terry
Hi Terry
The alloy tank arrived to Switzerland, I just have to pick it up by the dealer in the next days.
Did you get an information about suitable Monza caps from the factory, yet?
Raphael
Raphael......Thanks for th…
Raphael......Thanks for the website address re 961 Manuals. This site looks really helpful and could be a must for any new owners. I can not believe that, after 7 years of production, the Owner's Handbook still contains so many useless blank pages.
Terry......I have made a considerable number of phone calls and sent emails asking for advice. I still work full-time and all the call-backs from the factory have fallen during my shift times. Norton Motors needs to set up some form of response centre that can give advice either by phone or email outside their office hours.
Hi Phil Just as a thought…
Hi Phil
Just as a thought, have you tried phoning the dealer that took your money. I would have thought they would be willing to assist.
Graham
Raphael...........problem…
Raphael...........problem solved!!!
I have managed to fix the problem. You were almost spot on with how to change the illumination level of the speedo.Such is the power of the Internet and the value of being an NOC member.A good job I renewed my subscription.....last month!The solution is to power up the main lights.Next scroll through the speedo info panel menu until you find the battery voltage level. It is marked with 'V'. Plus 12.1 or 12.2Push and hold the select button until 'Ill' (for illumination) appears.This will show a number between 0 and 10.Push the button to change this number. 10 being the brightest level.After changing the level of illumination scroll through the menu once again to fix/lock the change, otherwise it defaults back to the previous setting.Which in my case was zero.I now have a very bright speedo and a not so bright rev counter clock.- Log in to post comments
Dare we ask which one matches the owner?
Phil, that's exactly what I meant with changing illumination. But still there has to be a problem with your "not so bright rev counter". This one seems to be illuminated by thebulb of the speedo... I mean, speedo and rev counter should have the same brightness. Is it possible that the rev counter bulb is damaged?
Previously charles_claxton…
The one that hovers around 1100 on tickler ð?
Hi Terry
Raphael
Terry
Raphael
Terry
Hi Terry
Raphael
I'll call them today but I'm pretty sure that the 2 1/2 inch Monza will do the job.
My tank is booked for pinstripes and I'm toying with getting it lacquered as the alloy is a pig to keep scratch free !.
Terry
Raphael
Terry
You were right about the cap. See pictures...
Attachments Monza_2.JPG monza_1-jpg- Log in to post comments
