Hi. I went out for a ride on my 99 today and twice I had the engine cut out on me. Both times it happened when I turned 90 degrees right from a T junction and then almost immediately (after about 5 metres) turned 90 degrees left (quite low speed and almost no throttle). On turning left the engine just stopped, (within about 3 metres of making the left turn). The bike started immediately again with just a short prod of the kickstart. I don’t get that cutting out if I reverse the directions, i.e. a 90 degree left turn followed almost immediately by a 90 degree right turn. My carb is a modern Amal Monobloc with less than 1000 miles use. I’ve ruled out electrics as I can swing the handlebars fully right then left with the engine on tickover and there’s no hesitation or cutting out.
It’s been a very hot day today - could that be something affecting the carb, or maybe it’s the fuel sloshing back across to to the left side of the float chamber when I turn left? I’m really puzzled by this one - anyone got any ideas ?
Carburettor
Hi Jonathan. Thanks for your…
Hi Jonathan. Thanks for your ideas. I don’t have a kill switch. I’ve done the ‘bars side to side’ bit with the engine running and the engine doesn’t falter. The problem ’feels’ like it should be electrical but I can’t find anything likely to cause it.
Hi Al. Thanks for your…
Hi Al. Thanks for your comments. It’s a Boyer dual output coil connected to a Pazon Surefire electronic ignition. I rode over 110 miles today over a wide variety of roads and only experienced the problem on two very similar junctions. Those two junctions were the only two where I had to do a ‘right-left flip flop’.
Thats an entertaining clown…
Thats an entertaining clown machine !!. Does the Pazon utilize the old distributor ? , Is there a lot of end float (axial clearance ) on the shaft?. What sort of ignition switch ?, Heavy bunch of keys flopping around?. Knee down cornering allowing heavy WD dispatch riders coat tails to cover carb intake !!.
Thanks guys. Robert, I’ve…
Thanks guys. Robert, I’ve got a magneto replacement ‘bean can’ housing the Pazon stator with a manual magneto sprocket. Lucas ignition switch (new) with only one key in it (no dangling bunch of keys). No overcoat - it was 27 degrees yesterday!
Neil, the Boyer twin output coil was approved by Pazon for use with their ignition units.
I’ll check the wiring around the headstock, as recommended. However, the bike has now done 500 miles since rebuild over all sorts of roads without any problems. If I had a wiring problem I thought I might have had an issue before, but maybe it’s a newly broken wire, although the handlebars weren’t turned that far to the left when the engine cut out. Also my loom goes round the lefthand side of the headstock, so it would be at very low stretch when the bars are turned left.
Everybody else has suggested…
Everybody else has suggested an ignition problem. So it is likely a fuel problem. You said almost no throttle. The fast change of direction changed carb fuel level substantially. At small throttle opening, very little fuel is consumed so a change in fuel level will affect air/fuel mixture more. Possibly so rich or lean that engine stalls.
Edit: Could be dependant on your riding style. If you have more or less bike leaning angle than you have..
Inertia...
Still thinking on the electrical route although Mikael's points are valid also. if is a "flip flop" situation you may want to look at other parts of the loom that can move under inertia.
Battery box, do you have an inline fuse holder that is floating in there, conductors exiting the battery box grounding out on tinware either by insulation "nick" or bullet connector exposed at a crucial position.
Wiring under tank is trapped, weight of fuel putting pressure on and breaking down the insulation, are the coils spade connected or eyebolts, any movement anywhere?
But as in my first post, when we all think its electrical, and as Mr. A. O. has guided us, ... its probably Carb.
Good hunting
J
hello ,are there any…
hello ,
are there any indicators fitted to the bike, drawing to much power. or creating a temporary short when turning
barry
Hi Barry. Thanks for your…
Hi Barry. Thanks for your idea - that’s a very interesting suggestion. I do have indicators - they’re low power LED ones but they are bar end with the wiring running through the handlebars into the headlamp (exiting the bars between the clamps via a rubber grommet). I’ll check the wiring for a short circuit possibility.
Thanks again
Disconnect...
... the power source to the indicators and go for a ride. Probably just go for a ride and see if you can repeat the error THEN disconnect the power source and re run the route...
J
Ask your self.....
Ask your self-was you using the indicators when the engine 'stop' happened? If it is a short then it will blow the fuse. There has not been any mention of such. So A O assumes there is no fuse. OR the engine 'stop' is not a short of the battery to earth, but more likely a broken feed. I did say 'hot wire' the ignition which could show/cover up the fault.
But of course this will turn out to be carburation!! But again as been said a carb fault should cough and sputter as it fails. An instant stop-no blown fuses or lights going out would 'say' an open circuit in the ignition?
Hi Al. Thanks for that. The…
Hi Al. Thanks for that. The indicators are fused and that fuse didn’t blow so I guess that means it wasn’t a short in the indicator circuit - thanks for reminding me about that fuse. I’ll look for an intermittent open circuit. I can’t get the engine to cut out when the bike is on the main stand so I guess that I need to revisit the route on which the failure occurred so that I can recreate the exact conditions.
hello , faulty brake light…
hello
faulty brake light curcuit. then again i suppose you could count that out if its fused also.
barry
which in our world means electrical!!! If it was carb it would not be so closely linked, "cause and effect" wise. Do you have a kill switch on the bars? check for wiring issues related to bar movement. Have you done a static test by moving bars side to side with engine running? or try leaning the bike over while running, (two of you recommended).
Intersting.
J
