Just dismantled the clutch on my '55 ES2 (trying to eliminate drag as usual) and found that adjacent the clutch sprocket was a plate with friction pads on one side (away from the clutch sprocket) and a plain side facing the sprocket which of course has inserts.
This does not show up in my parts list which shows only clutch plates and friction plates. What's this all about? Is it from a different clutch?
If I remove it I'm down to four friction plates rather than the five shown in the parts list.
Anyone come across this before? Could it be contributory to drag?
By the way, the parts book shows a circlip between the clutch outer plate (with the three holes in it) and the first steel clutch plate (plain). There's no such thing on mine. Should there be - for a '55 model and would it work without it as the outer plate seems to hold everything in place?
George
Previously George Phillips…
Previously albert_sheean w…
George
George,
You mentioned that your existing clutch basket/sprocket has inserts, which would be correct for that year. The plain steel plates for that year should have the tabs around the inside to engage with the cush hub. The friction plates should have their tabs around the outside to engage with the clutch basket.
This plate you mentioned, the one with inserts on one and plain on the other side? There is one like it in the late type (1959) models. It has the engagement tabs on the inside and it goes right underneath the clutch pressure plate. According to the parts drawings I have.
Assuming your 1955 model has a similar clutch to the 1957 models. It should have in order from the clutch basket insert side, plain with inside tabs, insert with outside tabs, this is repeated until there are four of each type held in place by the pressure plate.
The plate you mentioned with the inserts on one side and plain on the other is described as the "Clutch Plate End Assembly" and is part No. 21260 from the 1959 Norton Spare Parts List and it is common to the range.
Hope this helps.
regards,
Albert.
Thanks Albert. Sounds like I have a bit of a bodge of clutch parts.
Just trying to alleviate the problem of getting it into first gear.
George
George
George,
Hope this helps.
regards,
Albert.
George
George
George,
Hope this helps.
regards,
Albert.
George
Hi George,
Not too surprising, considering the age and such. My 1958 Model 19S now has a 650SS/Atlas type clutch as a result of my experiments with a belt drive kit from RGM some years ago. I never could get it aligned properly and it almost continually dragged. I finally gave up in disgust and assembled the clutch as money allowed. Oddly enough, the entire primary drive assembly as standard was actually lighter than the RGM offering. (RGM no longer offers that particular belt drive kit for some reason.) Make certain you have the clutch pushrod play adjusted a bit on the tight side. Minimal play helps when disengaging the clutch to engage first gear at a stop. Of course, I always pull in the clutch and kick though a couple of times to free up the plates before starting it up. I noticed that the later pressed steel outer primary covers will have a rubber bung right about where the clutch adjustment screw goes. Finding one of those probably wouldn't be a bad idea to save the hassle of resealing the primary case after an adjustment.
Cheers!
Albert
George
George,
Hope this helps.
regards,
Albert.
Thanks for that, Albert. You note that the "one sided" plate has the tabs on the inside meaning that is is "driven" by the gearbox rather than by the drive sprocket. All the other plates which have inserts are driven by the drive sprocket not the gear box. Does this mean I have a mis-match. Will it cause a prob? I read somewhere that in the late 50's Norton changed the design of the clutch such that all the "insert" plates had inside tabs (driven by gearbox) and the plain plates had outside tabs. I'm just not sure if you can mix them? My arrangement also means that the basket assembly is one plate short (joke there somewhere!). Again, note sure if this will cause a prob?
George
George
George,
Hope this helps.
regards,
Albert.
Thanks for that, Albert. You note that the "one sided" plate has the tabs on the inside meaning that is is "driven" by the gearbox rather than by the drive sprocket. All the other plates which have inserts are driven by the drive sprocket not the gear box. Does this mean I have a mis-match. Will it cause a prob? I read somewhere that in the late 50's Norton changed the design of the clutch such that all the "insert" plates had inside tabs (driven by gearbox) and the plain plates had outside tabs. I'm just not sure if you can mix them? My arrangement also means that the basket assembly is one plate short (joke there somewhere!). Again, not sure if this will cause a prob?
George
George,
Hope this helps.
regards,
Albert.
