It came to me during a recent delayed ride when it was getting dark, that waving my arms around to indicate moves to left or right was pointless and ridiculous. A few years ago I had bought a flashing indicator set for my Dominator but the light fittings supplied do not fit the headlamp. The supplier's advice was to drill out the thread on the retained nut inside the shell and then to use the thread and nut on the fitting to secure the headlight. Unfortunately, the threaded section of the fitting is too short to protrude beyond the retained nut, I am reluctant to remove the retained nut. Can anyone recommend a lighting set that will readily fit the bike or an alternative way of fitting one? I can always use the set I have on my BSA,
Thanks, Nigel Orchard
Here's my solution to the…
Very neat. Anyone got…
Very neat.
Anyone got suggestions for a led 6v indicator set? (Paul Goff has some, I didnt really want to pay £100 tho')
Flashing Indicators
Very neat! Thanks. Also has the advantage of spacing the lights a bit further out which I think is good. What is the size and threadform of the longer bolts and where did you get them and the spacers? Nigel Orchard.
Are you sure?
The idea of two daylight running lights? In the past Royal Enfield bullets had two such side lights, but in one case the sight of two small lights close together was taken as a car at some distance, turned out to be a bike 'very near'. Caused an accident.
This is a reply to Bob Mathews.
Flashing Indicators
I did something similar...
... but from flat 1/16" sheet tucked in behind the fork shrouds on my ES2. I made a bracket for the back that I bolted to the number plate. I agree indicators are all but essential these days.
I use 6v LEDs but had great difficulty getting them to work as the flasher unit needed more than 6.4 volts - would almost work unless I switched the lights on as well! From here: http://www.dynamoregulatorconversions.com/flasher-units-shop.php I eventually found some voltage step-up devices on ebay which seem to have solved the problem. https://www.ebay.co.uk/itm/334237098344
Navigator Indicator adapter
This is the adapter on my Navigator, made from stainless steel with an extended thread to pass through the headlight shell. and a female thread to take the indicator arm.
Hi Alan, I am sure. I'm not…
Hi Alan, I am sure. I'm not concerned by that silly urban myth. A car with a headlamp and sidelight out on the same side, is far more dangerous but as soon as it's dingy, dusk or later my headlamp (H4 halogen) is on - which totally outshines the two leds. My reason for using the led's is to be more visible in the daytime, in traffic around town as this is where the majority of accidents can happen.
Extender nuts?
Found them useful for a lot of applications e.g. fitting indicator leds. When too lazy to make specials on the lathe.
My solution....
The indicator units ar discontinued Halfords items. Note that LED bulbs are about 5mm longer than conventional ones and I had a bit of a struggle to fit these - I had to revise the internal wiring to give clearance.
Here's my solution to the problem. I made some brackets out of aluminium angle so as the indicators can be mounted below the line of the headlamp bolt. I then bought some stainless steel spacers and two longer stainless cycle thread bolts of the required size. I also fitted daytime running led's that are serious bright but hardly draw any current.
