Lay down g/box. 350cc international featherbed
Hello fellow comrades
(1).  What size g/box speocket should I use. 19 or 20 tooth
or would it make virtually no difference.
(1).  What’s the correct length for the clutch pushrod ?
kind regards Alan
Hi. I have the same model Norton as you. I believe that the sprocket should be 19 tooth. I found that over-gearing spoils the performance.
Best wishes, Doug
