Frame Rear Tank Mounting
Hi does anyone know if the mounting shown in the attached (circled in red) are available from anywhere still?
Frame mount for Petrol tank (rear)
Thanks Colin
...Stu Rogers 01945 585116
In reply to by Jon Newton
Thank you Michael I’ll give Stu a call see what he says
Hi Colin,
   I am guessing this page is from the 1947/9 parts catalogue and the illustration makes it look like this is a separate available item, but it is a malleable cast iron lug which was permanently brazed to the frame assembly. Even back in the day these would only be available by individual request from the factory. There have been a couple of restorers over recent years who have had lugs cast to build replica frames, but it is not something that is readily available.
   Jon has probably got the best suggestion as Stu has made several of these frames.
