Hi does anyone know if the mounting shown in the attached (circled in red) are available from anywhere still?
Frame mount for Petrol tank (rear)
Thanks Colin
Manx frame lug.
Hi Colin,
I am guessing this page is from the 1947/9 parts catalogue and the illustration makes it look like this is a separate available item, but it is a malleable cast iron lug which was permanently brazed to the frame assembly. Even back in the day these would only be available by individual request from the factory. There have been a couple of restorers over recent years who have had lugs cast to build replica frames, but it is not something that is readily available.
Jon has probably got the best suggestion as Stu has made several of these frames.
Richard, many thanks for the…
Richard, many thanks for the good info
Regards Colin
Assuming you need it for an Inter?
If not, I have this lug for an ES2. It has been removed and is yours if it is needed. Manx different again.
i have some un machined…
i have some un machined castings i think, if you still need one....
...Stu Rogers 01945 585116
