Rear light Double Bubble!
Looking through my bits and came across this a Lucas/Britax/Wipac?  A rear light with two bulbs. I wonder if it can be wired to have two, yes dual combined Tail and stop lights?
Site won't let me load a photo!
Okay now managed it!
John
Hi John,
After 63 years I had to rebuild my rear light as the bulb had been in for 50 years and rusted solid. By dismantling 2 other units I salvaged enough bits to rebuild it.
If you want to make it into a twin bulb unit you will have to swap the bulb holders for offset pin units so dig down into your pile of old bits and pieces and salvage a pair, they should be interchangeable.
Dick
Thanks, Dick. I will do just that, you know I hadn't thought of the pins being different on the bulbs! Duh!
It would be impressive though , wouldn't it!
John
Photo won’t load ..... what Like this?!!
Bulb
Hi Richard, that had crossed my mind, but I dismissed it, I could always look at a ventilation solution!
John
