In a previous thread about Dommie cylinder lubrication, one reply mentioned the possibility of the crankshaft not being parallel to the crankcase mouth joint face. Apparently it's a common problem and may be up to 15 thou in bad cases.
My engine shows a misalignment of 15 thou, and I wondered if this might be a possible cause of its tendency to seize the left piston, (though why only the left I can't imagine).
It occurred to me that slightly different length conrods could also be a cause of this misalignment so I swapped left for right. This halved the measurement to 8 thou, so it seems the fault is a combination of conrods and crankshaft/case alignment. This works out as a tilt to the left of 0.0612?.
My question is: is this within acceptable tolerances, or should I try and have the crankcase mouth milled down to level things up? I have a spare 40 thou thick steel compression plate lying around. Would it be possible to mill this to make a sloping spacer?
Previously Rob Bradley wro…
Anna has a point here beca…
Anna has a point here because crankcases need to be a matched pair. The crankshaft and camshaft bearingsneed to beline-bored - hopefully at 90deg to the barrel bores!
But Rob has the cases he h…
But Rob has the cases he has...As Anne suggests, checking once as shown might just indicate one rod being slightly shorter than the other. But since half the defect remains when the rods are swapped over, the crank alignment must be the issue. So a taper pack ought to bring the barrels into right angles to the crank. Are there specialists who can measure this sort of thing with special equipment?
Previously David Cooper wr…
hello yes a slided rule or a vernier caliper would do the job . if you know how too use one. yours anna j
Hi Rob, How or where are y…
Hi Rob,
How or where are you measuring to establish a 0.015" alignment error?
If you can find someone with a large enough lathe you could mount the crankshaft (with the crankcases assembled) between centres, then clock up the crankcase mouth by attaching the dial tast indicator to the carriage of the lathe. This would check for parallelism between crank and crankcase mouth. making a tapered base gasket is, IMHO, a bodge.
Thanks for all the respons…
Thanks for all the responses, I was beginning to think this thread wasn't going to take off.
David
A friend has offerred to check the crank in a lathe, so I'll mention your idea of doing it with the cases assembled.
Let me try to explain more clearly what I'm up to. Bear with me, it's complicated! (At least to a non-engineer like myself it is).
In order to find a possible explanation for the tendency for the left piston to pick up on the sides (not the thrust faces), following a suggestion from Bill Moline in my previous thread on cylinder lubrication back in November I checked for misalignment in this SS crank in an 88 Dommie by pushing an 11/16" x 300mm long silver steel round bar through both little ends and bringing it down to the crankcase mouth. When the left end is touching the crankcase barrel joint surface there's a 0.015" gap, measured with feeler gauges, under the right hand end of the bar.
If I remove the conrods and stand them back to back on a sheet of plate glass and sight through the little ends I can see that the right bush is slightly higher than the other. (Only slightly, as the 11/16" bar wouldn't fit through both little ends at once, but you can feel when pushing it through that it needs a little wiggle to avid hitting the edge of the second bush).
If the crank was parallel to the barrel base surface then swapping the conrods right for left should transfer the 0.015" gap measured under the bar from right to left; however, the gap remains on the right and is reduced to 0.008". I interpret this as meaning that the crank effectively slopes downwards from right to left relative to the barrel base.
There is a further complication: the above measurements refer to the crankpins being positioned towards the front of the engine i.e. about 90? rotation. Of course, the bar can alternatively be brought down with the crankpins to the rear (about 270?). This alters the measurement under the bar from 0.015" to zero, which I take to mean there's something amiss with the 88 crank itself. In support of this, I have a crank from a 99 and with this in place the gap under the bar is about 0.002" whichever position the crankpins are in, and zero if the conrods are swapped round.
A further complication is that the bar can be rotated horizontally by a small amount because of the running clearance in the big ends and the less than perfect fit of the bar through the little ends, which alters the measurements. I've tried to take them without introducing any twist but even so, because of these clearances I guess the feeler gauge measurements can't be accurate to better than a couple of thou.
With each crank in turn mounted in the cases I've checked for runout with a dial gauge on the crankshaft ends (where the oil seal runs on the right and where the alternator rotor fits on the left). The 88 crank shows 0.001" difference between TDC and BDC, and 0.001" between 90? and 270? for the left (drive side) and zero TDC/BDC and 0.0005" 90?/270? on the right.
The 99 crank was 0.0005" TDC/BDC and zero 90?/270? on the left, and 0.001" TDC/BDC and 0.001" 90?/270? on the right.
Measured on the flywheels (tricky because of the balance holes and the narrowness of the 99 crank at one section) there was a maximum runout of 0.002" on both cranks.
Whether these measurements are meaningful in any way I can't say.
The next step is to see what my friend can do with his lathe.
Ultimately I just want to know whether any of these misalignments are significant or whether they're just a red herring and the cause of the piston problem lies elsewhere, bearing in mind that the seizing has happened with both the 88 and 99 crank/barrel combinations, using the same crankcase.
I've had the 88 barrels sleeved, rebored and bought new GPM pistons so I'm itching to put it back together as the 88 it originally was and enjoy riding it again ASAP, but if there is an underlying problem I suppose now's the time to tackle it.
An alternative is to throw even more cash at it and have the 600 barrel rebored to +.040 (because of the smoking, which is another topic) and buy new pistons for that (as well as having the crank balanced to 80% from whatever it is now which makes it vibrate, but again that's another topic).
Ifeverything is within tol…
Ifeverything is within toleranace with the 99 crank fitted (which it appears at a glance to be), the problem lies with your 88 crank. Something as simple as the flywheels being the wrong way round or even a bit of muck under the crank cheek when the crank was last reassembled could be the problem. It's unlikely (but not impossible) that the 88 crank is distorted. Might be worth a quick strip and check. The crank that is...
The left side of the 88 cr…
The left side of the 88 crankshaft was metal sprayed because the inner bearing race was a loose fit on the shaft. The workshop that pressed the new inner bearing race on for me didn't get it fully on so that it wouldn't have been possible to bolt up the crankcase halves. When I pointed this out they said they'd got it on as far as they could, exerting so much force in the press that the crankshaft was flexing, though they assured me that it wouldn't have bent it. I insisted they pull the bearing off and check there wasn't any swarf jammed behind it and it came back with the bearing fully home on the shaft so I'm pretty sure there had been.
I suppose it's possible these clowns haven't done me any favours and I certainly won't be heading back to Doncaster at any time in the future.
But bear in mind that the left piston seized even with the apparently straight 99 crank fitted, so I'm not convinced the 88 crank is necessarily causing problems.
It sounds to me like your…
It sounds to me like your 88 crank has not been ground correctly (concentric with the original journal) after metal spraying and that along with maybe some distortion has lead to your problems. The 50,000$ question is did the barrel sleeve and rebore get done by the same outfit that metal sprayed your crank? If the answer is yes, then an independant check of roundness, size, surface finish and parallelism would be worth investing in. Can you let us know who this outfit is so we can all benefit from your experience?
The barrel sleeve and rebo…
The barrel sleeve and rebore (not the metal spraying or bearing fitting) were done by S.E.P. (Service Exchange Parts) of Kegworth, who were recommended to me by two vintage bike enthusiasts. They seem to do quite a bit of old bike work. I don't know yet how good their work has been, but they came across as knowing what they were talking about. Even so, they disputed that my 88 crank would have been balanced to 80%, but when they checked it that's exactly what it was. (By the way, it was balanced in 2004 by a chap called Dave North in Leicestershire, who I believe used to race Nortons).
Regarding your idea of checking the crank in the cases on a lathe, my friend said he could try that, but another way would be to upend the crankcase (minus studs of course) on its barrel joint face on a flat surface and measure to the crankshaft ends with a height gauge.
The bearing should not be…
The bearing should not be as tight on the shaft as that .A simple bit of hand fetling with blue black emery was needed.Crankcase halves do not always go back together with the surfaces flush. Rods can go out of round, Manufactured on old worn machinery anything is possible.My opinion is it will be ok with a bit more clearance in the bore. Dommies are prone to drive side siezure, Look up old posts.There are a few differing theories as to why this happens. The 88 is the better motor,i was happy to cruise at 80 on mine ,The 99 is rough by comparison.
" The 88 is the better mot…
"The 88 is the better motor,i was happy to cruise at 80 on mine ,The 99 is rough by comparison."
I have ridden good and not so good 88s and good and not so good 99s. They are both good rides when put together properly.
Previously robert_tuck wro…
It went from one extreme to the other: too loose after an over-enthusiastic bit of hand fettling with emery, then too tight after metal spraying and grinding.
The crankcase halves seem a good fit and there hasn't been any oil leakage from the barrel joint even with just a thin paper gasket.
I asked for 0.0045" piston clearance with the rebore so I hope that will be enough.
The 88 was such a smooth revvy motor that I was disappointed at how rough the 99 felt in comparison, but I was putting it down to imperfect crank balance, though I haven't had the 99 crank BF checked yet.
I would also check that th…
I would also check that the ignition timing is the same on both cylinders if you are running a distributor or a mag, this is a known issue.4 and a half thou should be ok for the pistons although you may experience a bit of cold slap.. The final hone grade should match the type of ring material. Check the ring gaps in the bore ,they sometimes are nil!.
I've spent some time in the past straightening the distributor shaft to get the timing more or less the same on both cylinders, and I've marked the alternator stator so I can use a strobe.
I'm assuming cast iron rings (GPM) and maybe 220 hone, but the people doing the rebore should have known what they were doing and they had the pistons to hand. Yes, I must remember to gap the rings. About 10 thou?
Previously Rob Bradley wrote:
The barrel sleeve and rebore were done by S.E.P. (Service Exchange Parts) of Kegworth, who were recommended to me by two vintage bike enthusiasts. They seem to do quite a bit of old bike work. I don't know yet how good their work has been, but they came across as knowing what they were talking about. Even so, they disputed that my 88 crank would have been balanced to 80%, but when they checked it that's exactly what it was. (By the way, it was balanced in 2004 by a chap called Dave North in Leicestershire, who I believe used to race Nortons).
Hello Rob Now after reading your threads on this problem of yours, Theres a cupel of issues here S.E.P are one of the best engineering company's you can get in this country, the first thing that comes to my mind is the Gardie pistons you have, Have you weighed the and measured both of them for there lengths and the next thing that comes to mind is the Crank could of been in the past reassemble wrongly and too balance a crank right you need V bocks and 4 clocking dial guages , Mercer dial guages are one of the best you can get just take look on E-bay garage tools and my advise too you is too take all your engine part to S.E.P and tell him what you like him to check out . and see what He thinks too the situation you now have, as at the moment your firing blanks in too the thin air, and getting no where , he has the expert know how, too do all the measurement checking and re-balancing the crankshaft but you need too take all the bottom half of the engine including the barrel ,and do not forget the taking the pistons as well, then you know that the job will be done right , then you can get on with enjoying you rides out, But in the Classic and Vintage world there is now a big thing going on with showing your nice machine , as the Bristol Branch have shown with there Win of Best stand in the Show , so we all need to take more apart of this showmanship on apart for your Club and Branch , well I do hope you take my advise and get your nice model 88 sorted out , Yours Anna J Dixon
Hi Alan, 10 thou ? sounds…
Hi Alan, 10 thou ? sounds about right,(without looking it up!) , remember to stagger the gaps around the piston (i forgot last time),might be worth checking that the pins are able to move in the piston easily when hot, I have had a tight one.
Alan? Who he?
Anna Thanks for the reassu…
Anna
Thanks for the reassurance about S.E.P., I'll be more confident about going back there in the future. Probably soon, with all my bits to be checked.
They did check the balance factor of my 88 crank (so that I would know what factor to apply to the 99 crank if I want to use it again), but maybe they wouldn't have noticed any misalignment if they weren't actually doing a rebalancing?
I have actually weighed the new GPM pistons (with gudgeon pin, rings and circlips) and there was a difference of just 1.2 grams. Never thought of measuring the length though. But I don't see how that relates to the recurring left piston seizing problem.
I prefer riding to going to crowded shows, but after restoring it in 2009 (after 37 years of ownership) I did show the bike at the National Rally at Donington, and at Stafford on the Historic Police Motorcycle Group stand, and on the November page in the 2011 NOC calendar if you still have a copy. Some time I must write up its history for Roadholder, it's quite unusual being a 500cc police bike.
Anna
They did check the balance factor of my 88 crank (so that I would know what factor to apply to the 99 crank if I want to use it again), but maybe they wouldn't have noticed any misalignment if they weren't actually doing a re-balancing?
well as pistons go there not all the same length I have a number of Hepolie pistons and the in pairs but there not one pair that the same lengths as you have GMP piston they may two different lengths there sent you but only by a very small amount of difference, the original pistons for norton were BHB brico-covo all apart is the British heavy Industries witch Hepolie and earlier Hepolex , Brico-covo did there piston rings at one time. then every thing was brought in to one industry under Automotive Engineering , and then in the 1980s copys of AE pistons were done by JP pistons in Australia and GMP piston in Italy both theres are copys but to my mind JP piston have the edge over the GMP piston, as these are heaver than the Original british made ones so you have to rebalanced your crankshaft any way , to compensate for the exter weight , so its a trip to S.E.P . as for the seizing up problem by using GMP piston are a different metallurgy too the originals and they have more lightly too of been re-bored the original specification for over size piston ,but not taking in account the expansion rate of the GMP piston and these need a extra thou for the expansion , yours anna j
The crank was balanced for…
The crank was balanced for the previous pistons which were also GPM.
Are you saying GPM pistons need 0.0055" clearance?
I've read forum posts on both JP and GPM pistons and I think it's true to say opinion was divided. Andover Norton have decided to go with GPM. It's true my previous left GPM piston seized, but so did the Heplex in the 99 barrel, and whatever was fitted when I bought the bike in 1972, possibly Hepolite but not, I think, GPM.
I wonder how important it…
I wonder how important it is to have both pistons the same weight? If there is a difference it will only affect the rocking couple (side to side) and that must be tiny compared with the major out of balance in a pair of single cylinder engines running in phase side by side.On JP: when I removed a new pair (maybe a couple of thousand miles old) (to replace my worn out big end bearings) I found one had hairline cracks on both sides from gudgeon pin hole to crown (but not over the top). I've no idea how long it had been like that, or what would have happened had I not discovered it. And I've no idea if the ones in my bike now are the same.
well I no idea what your bore size is now , but from standard the expansion clearance would be better at 0.003 thou as Norton were bored to narrow a tolerance for the expansion of the piston , and gpm piston have a different metallurgy to the original pistons , and they will expand quicker than the original pistons , but after reading your threads there something not right with this engine and it need some looking into by S.E.P the man with experience off all types of engines , yours anna j
Bore size is now back to s…
Bore size is now back to standard 66mm for an 88, in new sleeves.
I took the engine to S.E.P. today so I hope to know in 2 or 3 weeks what's what.
His first impression was that crank misalignment was unlikely to be causing this problem and only on one side. Maybe a bent conrod? Other suggested causes are weaker mixture on the left or different ignition timing each side.
On the oil burning issue, he thinks the valves are too loose a fit in the guides, the inlets being Commando items as recommended for all twins from Andover Norton. He says it's usual to have to ream guides to fit the valve stems but these were loose from the start. I have an old pre-1960 head spare and the valves are a nice fit in the old guides in that. But I suppose that's a subject for a different thread.
His first impression was that crank misalignment was unlikely to be causing this problem and only on one side. Maybe a bent con-rod? Other suggested causes are weaker mixture on the left or different ignition timing each side.
well let hope you now get it sorted soon and you find that Bronze Valve guides are better than your cast iron valves guides Carlbro valve are some of the best, I get my parts from RGM motors and up to now I am happy with there service but then there our Steve Maney performance parts , yours Anna J
Well, the engine's still…
Well, the engine's still at SEP 7 weeks on. So much for their 2-3 week estimate. I've been promised it next week, but that promise has been broken twice already so we'll see.
As far as I know, the only misalignment was in the crankpins, which has been corrected by re-grinding to -.030" from -.010". I believe oversize valve guides are to be fitted and reamed in the hope of controlling the oil burning. Seems the new guides I fitted earlier from AN weren't up to much.
Anyway, we'll see next week what the final verdict was (or the week after, or the week after that...)
Hello Rob Make sure the oil ways are cleaned out on the inlet side of the cylinder's and cylinder head and the crankcase as well , this is the one that runs down the back of the cylinders from the inlet side of the cylinder head, This is most important as this is where it gets blocked and then there is a build up of oil in the cylinder head around the inlet valves then is only try's to find its own way out , mostly down the valve stem and into the cylinder chamber too be burned with the fuel , the end result of you think you need a rebore, as when the engine is running you have white or blue smoke coming out of the silencer ends, and the other place that get a oil leak in to the cylinders is from the rocker tunnels where they meet in-between the cylinders and cylinder head it get by the gasket and gets sucked into the combustion chamber on the downward stroke, this is very common on Norton twins so be-aware of this problem , Yours Anna J Dixon Technical officer for the EASY YORKSHIRE BRANCH
A WARNING! I finally got m…
A WARNING!
I finally got my engine bits back, after 8 weeks at SEP (and an abortive 2-hour round trip because they were closed when they should have been open according to their website).
The crank has been ground to .030 to correct the misalignment they claim to have found. I commented I'd have to split the crank to make sure there were no traces of grinding grit left but was assured it had been very thoroughly cleaned and to dismantle it would risk misaligning it again. I was told it was ready to go back in the crankcase. They had put it in a clean plastic bag for protection and it looked superficially clean so I thought no more of it. I trusted the experts (willl I never learn!) and after all, SEP came highly recommended higher up this page.
When I got round to starting the rebuild and took the crank out of the bag I felt a certain grittiness. On closer inspection I found there were deposits of coarse grit stuck in the balance drillings and in the corners of the flywheel casting! There may well be more lurking in odd places. If I'd gone ahead and rebuilt the engine it wouldn't have been a happy motor.
On top of that, one of the new valve guides they fitted seems to have been reamed under size so the valve stem is sticking. I wonder if I can correct that with a gentle lapping using fine grinding paste?
No doubt they would say it was my fault for pushing them to get the job finished (within 8 weeks when they had quoted me 2-3 weeks).
All I can say is if, to quote from a previous reply, "S.E.P are one of the best engineering company's you can get in this country" then we're in a pretty poor state.
I suppose I now need to find someone competent to check the regrind and make sure it's been radiused correctly.
Given that I won't rest now until the crank is properly cleaned out, is there any way I can dismantle it and be sure of it being perfectly aligned when I put it back together? That's assuming it is actually in alignment now, of course.
For an undersizesd valve g…
For an undersizesd valve guide, what I did was this (purists look away now). Screwfix do a cheap set of engineers drill bits. I selected one which was a good sliding fit in a correct valve guide and then used it carefully to open out the undersized guide. Worked a treat. I can hear the howls of outrage already.
re: crank assembly - make…
re: crank assembly - make sure you follow the right book (if there is one...) Haynes famously give the wrong torque for the bolts. They give 35 lb.ft. and it should be 25.And a couple of studs are apparently closer tolerance then others and act as dowels - anyway I'm sure there are better people to advise you than me. I broke my first set of bolts...
I bought a new set of 5/16…
I bought a new set of 5/16" bolts and studs from AN recently, and was aware of the Haynes manual error.
I rang SEP this morning and was told the grit can't have come from them. A mystery, since the crank was in a polythene bag when they handed it to me and I noticed the grit as soon as I took it out.
Frustrating, because I was going to take them my 600 crank and barrel, and my Commando barrel for reboring.
Rob, I have trawled throug…
Rob, I have trawled through this thread again and I think the problem is with the left (drive side) end of the crank which was metal sprayed. It would seem that following the metal spraying, this was ground slightly off centre. It would account for the measured error varying depending on the position of the crank. I am not a great fan of metal spraying. I had a metal sprayed crank which was fine until the sprayed bit lifted at speed seizing the engine. I was not amused. Sorry to hear of all your tribulations. It might be worth trying RGM or SRM or one of the established specialist bike restorers rather than a general machine shop. They should have theappropriate expertise.
I can't argue with your r…
I can't argue with your reasoning, Gordon, and appreciate your efforts.
This engine had a habit of seizing before the 88 crank was metal sprayed, and also seized with the 99 crank in. That's not to say that the metal spraying won't give way at some point, as you experienced, but I think that's a separate issue. Just out of curiosity, what exactly happened when your metal sprayed crank failed? I would have thought the bearing race would loosen and give some warning of impending disaster. Before I had it metal sprayed I rode to Plymouth, did the Colombres rally and rode home wondering all the time what the faint knocking noise was, but it didn't fail catastrophically.
Every "expert" I take it to will find something different that they can charge me to fix, but I've thrown more than enough money at this problem and I want to be back on the road, so I'm inclined to put it together and see what happens.
Once I've got the crank free of grit of course. There seem to be two options there: leave it assembled and flush through the oilways in the hope that will dislodge any grit; or dismantle it and after bolting it back together get it checked for alignment by a (different!) crank grinding shop.It's not as if there's likely to be anything really stuck inside because it was stripped and thoroughly cleaned before it went for grinding, so maybe the first option will be enough.
Apart from anything else, I heard yesterday that the bike is wanted by the police! In a good way: its previous owners want me to display it in London later in the year. (See NOC calendar 2011 November).
I took some photos and vid…
I took some photos and video of scraping off the flywheel grit. It's also around the nuts and locking plates and in the balance drillings.The videos are probably too large to post here and are .mov so I can't easily edit them. The photos aren't very clear because the camera focused on the background, but I'll attach a couple in case anyone's interested. I'd send them to SEP if I thought they cared about their workmanship.
I'm pretty sure they're glass bead fragments, or sand, but when I suggested this to SEP they said it hadn't been blast cleaned. The crank as they received it was as it came out of the engine and couldn't have had grit stuck on it because I tend to use oil rather than sand as a lubricant. Maybe after I got the crank back someone broke into my garage and blasted it without telling me. Yes, that'll be it. Makes sense.
grit-from-flywheel12330011-jpg
Stripping and reassembling…
Stripping and reassembling the crank won't put it out of alignment, so go ahead. Just make sure you mark the flywheel with T and D for timing and drive side (or something similar) to make sure it goes back the way it was. Not that getting it wrong should make much of a difference. The crank that failed was a BSA crank bought expensively from a dealer down south - paid the price as it was advertised as standard journals. Only when it arrived I discovered it was standard because it had been metal sprayed and reground. A shame he forgot to tell me that. The sprayed big end let go causing the instant seizure and an S shaped con rod. I must have got a couple of hundred miles out of it before it failed.
The grit could have been i…
The grit could have been in the bag before they put the crank in it. Having now had the crank reground true, has the regrinding process gone through the metal spraying on one side of the journal? Your regrind has gone from -0.010" to 0.030" that's a 0.010" cut (20 thou off the dia) what you need to know is how thick was the metal sprayed surface before you started and being as the journal was not true before the grind then the metal sprayed band will vary in thickness. Sounds to me like SEP is to be avoided. If you don't want to seperate the crank a good wash in clean petrol should suffice.
You might want to examine the conrods a little more closely for the small end being parallel to the big end in two planes. That would/could give you the seizing problems if the piston is cocked in the bore. I'm sure you have spent a fortune on this crank. Two new conrods might be money well spent, particularly as the originals could be 50+years old
The grit was packed into a…
The grit was packed into a corner of only one side of the flywheel casting and had to be scraped off, so it couldn't just have been lying around loose in the bag.
The metal spraying on my crank was done to stop the drive side main bearing inner race from being loose, so once on it should stay put; Gordon's was on the big end journals which is a bit different.
SEP say they checked and the conrods are straight. Not that that fills me with confidence. I agree with David's assessment of SEP.
I always mark mating assemblies before I dismantle them, so I know the cranks and flywheel go back together the same way round.
Anna Dixon's reply in this thread on 24 March implied the crank could become misaligned after dismantling, but I couldn't follow her explanation of how to avoid this. SEP said there's a chance of misalignment when the bolts are loosened because there's only one locating dowel on each side. But I must say it doesn't feel to me as if there's any potential for movement once the cranks are located on the dowels and the bolts are in even loosely.
Bacon's Norton Twins Rest…
Bacon's Norton Twins Restoration mentions two of the bolts also being close tolerance. I haven't seen that in manuals... is it true? Mine were very stiff to get together and I still wonder if it is correct. If two bolts are different from the others then there is yet another trap to fall into.And should nuts be 'staked' or use thread sealant and/ or rectangular tab washers on all of them?
An interesting point. I'v…
An interesting point. I've just checked Bacon's Norton Twin Restoration (page 47 in your hymn books) and he mentions the two close-fitting studs being introduced in 1957, and on the 650 in 1961, but not, as I read it, on Commandos. Although, as the two special bolts were associated with longer nuts in the 1961 650, and these nuts were used on Commandos up to 1973 (if I read it right), then it may be that early Commandos had the two special bolts as well. It's not clear to me whether he means the special bolts were used on all twins from 1957 to 1973, in which case my 1963 88 crank should have them. I'll have to measure all the bolts when I split the crank.
When I ordered a complete set of 5/16" crankshaft fixings from Andover they sent: 8 nuts 067533; 2 locking plates 067534; 2 studs 067553; and 4 bolts 067535. All four bolts are the same, then, though whether they're all close-fitting or all loose-fitting remains to be seen.
I am confident someone such as Phil Hannam will have the definitive answer if he happens to read this.
All the twin cranks I've seen have had the nuts centre punched. But I suppose thread sealants hadn't been invented when they were first assembled. Maybe someone can enlighten us as to whether punching or chemical locking is better? I'm pretty sure tab washers are only used on each end of the two studs.
Well the 1954 Dominator Crank I did did not have T and D on each side of the fly wheel in the center of the Crank So you had to puch mark it so you know where its all fitted before you took it apart,
I would of though this would of made some sence ! The first 650 was built on November 7th 1960 and this Is No where in Roy Bacon books or anything much about the 650cc Norton Manxman , We had to do all the reseach on this machine as even the Norton Owners Club as Not even bothered to do any reseach on this motorcyles as they where export machines its just like other Norton motorcycles that where for export, like the 1950/51 model 77 .500cc machine that was exported to Australia and New Zeland , And the EC member do not seem to that much bothered about any of the History of Norton motorcyces from day one, why we have this Executive commttee that dose not seam to be in tune with any thing Norton, yours Anna J
On Page 52 of Bacon's 'N…
On Page 52 of Bacon's 'Norton Twins' he introduces the 650cc twins with a good description of the Manxman.On the foot of the same page he tells us how it appeared in Europe in the Amsterdam show, and there is more mention on page 53.Then in the Appendix he describes its colour.Page 67 of 'Norton Twins Restoration has a close up photo of the engine of a Manxman, and there is text on Page 12.All this for a bike that wasn't even aimed at the UK market might seem a bit over the top.Apologise to Mr Bacon, please!
But anyway - can you add a…
But anyway - can you add anything to Rob's questions about details of crank assembly please, Anna? Are all the holes the same size, and are all the studs + bolts supposed to be the same size or is there a pair of studs/bolts acting as dowels in there somewhere?
Well 5/16 studs seem to be standard on most early Norton Cranks and punch marking in-between the stud and nut is the best way of locking the thread two or three pop marks should do the trick, Now back to Roy bacon Book yes there is a bit of a mention on the Norton Manxman but that's just out of curtsey to the mark , there not much else in there but the colour but No colour codes or any thing they did not do a Manxman deluxe model as He says or a sports model , just a very fast cruiser and a very nice bike to own and ride, he did not say any of this did he, and he is out with the year numbers by months earlier than he say that they are, its like he says the first 650 was number 100200 , but its is wrong the first 650 was number 93601 built November 7th 1960, nearly one year out, that's a long time to be out on Norton's manufacturing ,What else is out of data in his books too , And to say for a long time the Norton owners club took this book as the bible on Norton twin restorations, But did not question this book of Roy Bacon , And for a long time no one had even thought of doing any research on the 650cc machine, and it was taken for granted that Roy bacon book was right information on the Norton models , Until me and Phil Hannan started to dig up some information on them and found that the previous information was bit out of date to say the least , I think its high time to do a better job of his books and start all over again and get some real data first, and do some better listing of parts and part changes and there dates that would be more helpful to a Norton owner and restorer and some better date on colours to, and there years and colour changes and some paint codes or very close matches but this need to be a team effort and coming from with in the executive committee or members that can work as co-ordinators to a book for the Norton owners club to be published by the Norton owners club and not some outside source, yours Anna J Dixon
I've dismantled the crank…
I've dismantled the crank and measured the bolts, which as far as I am aware are the originals, as I'm only the second owner and have had the bike from 1972. Also, the old bolts are better made than the new Andover Norton items which are slightly short and don't have the circular seating (almost like a built-in washer, I don't know the technical term for it). The AN items vary more in diameter as well, such that one of them won't even go through one of the holes. I must admit to being a bit disappointed, I expected better from them. I may even re-use the originals.
All four old bolts measure the same diameter to within 0.0005", so on this crank at least there are no bolts acting as dowels.
Now how about starting a separate thread about the Manxman for those who are interested, and leaving this one to we sad persons who want to talk about crankshafts?
The tight fit bolts were a…
The tight fit bolts were a Bracebridge St fitment, Once the production was switched to the AMC works they did things their way,Probably dropped the idea.They were dismissive of the way things were done at Nortons.John Hudson (a fine Engineer) was equally dismissive of the AMC ways of doing things.
Rob - are all the holes th…
Rob - are all the holes the same size as well? You say 'one won't even go through one of the holes'...I remember some of mine were very tight and I was worried that bits might get scraped when tightening it all together - with the risk that the cheeks won't be in proper contact. I did'nt measure anything, partly because I didn't expect any problems, and partly as I hadn't read Bacon's remarks.My bike was from Plumpstead in 1963.
Rob - are all the holes the same size as well? You say 'one won't even go through one of the holes'... I remember some of mine were very tight and I was worried that bits might get scraped when tightening it all together - with the risk that the cheeks won't be in proper contact. I did'nt measure anything, partly because I didn't expect any problems, and partly as I hadn't read Bacon's remarks. My bike was from Plumpstead in 1963.
ARRRRR ! now he tells us Its a Plumpstead job no wonder you having a hard time with this crank if the bolt are tight fit use a reamer to the right size and have the holes in the crank reamed out, then you get a good fit, and are the number on the left and right crank webs the same numbers because you just could have two different crank web half's and it will give a slite out of alinement
yours anna j
Sorry, I didn't mention u…
Sorry, I didn't mention until my post last Friday that it's a 1963 Plumstead engine. Yes, the holes are different sizes, very slightly, but all the old bolts will go through any of the holes. It's just one of the inferior quality new bolts that hasn't been finished properly and is oversize, with a rough surface, that won't go through one of the holes. Some of Andover Norton's spares may be made from the factory drawings, but these bolts clearly weren't. I think I'll send them back and re-use the originals if I can't find a supplier for parts of equivalent quality.
Markings on the crankshaft webs are as follows: Both are stamped 88SS and are marked with an inverted triangle containing the letters DD above a letter F The timing side has what looks like a part number: T2022/3 and 9044DN2 The drive side has 9044 on one edge of the web and 9044DN2 on the other
So it looks as if they're a matched pair.
If the threads have not be…
If the threads have not been deformed i would re-use them. A genuine 88ss crank is stronger than a standard one with a different core size. Hard to replace ,so look after it.
I thought I was looking af…
I thought I was looking after it by taking it to SEP. Unfortunately they decided they needed to take .020" off to realign it, and as it was already .010 undersize it leaves me with only one more re-grind.
The first Dominator manual I got, back in 1973 from Taylor Matterson, has a page of re-grind diagrams at the back showing the big end journals radiused to .094" - .090" and stating this is important. The finish from SEP is variable and is more of a chamfer than a radius in places, which concerns me slightly.
Well you do not measure the connecting rods in this way , there measured from large end journal to the small end journal when there removed from the crankshaft. And when splitting and crankshaft you must mark the crankshaft alignment by punch marking along a steel angled ruler or long set square so the crankshaft is in line with the left and right hand sides and the center flywheel before you remove any of the bolts that hold the crankshaft together and making extra sure you re-assemble it back in the same way as you dis-assembled it. and then you can measure the connecting rods and check there weights too and recording this as you go and check and record the said part before reassembly. then you have and record of weight's and length and width of the parts in question , and it may-be that your crankcases are out of line or do not match each other , just trying to help, yours anna j
