Dominator rear wheel offset
58 wide line frame, what is the off set from the hub to the rim please,?Preferably the centre line of the rim to the hub behind the drum & spocket, as I've aquired a hub with nothing, no spokes or rim & I usually use the taverener wheel building jig as building wheels bare like this is alien to me. I do wish people wouldn't strip the wheels until they're ready to be done
I ask the measurements from the centre line because I'm using a 2.5 rim instead of a 2 x 18
Paul, Slimline rear wheels are built dead centre, ie No offset. I can't imagine that widelines would be any different unless someone would care to comment.
There is an offset at the front wheel however.
We usually quote WM 1, 2 or 3 in rim widths but makes no difference where there is no offset.
For offset details, check with the RGM website under Technical Tips.
Thank you for the information it will get me going in the right direction, front wheel not a problem I borrowed the wheel out of my Navigator to copy.
The rear wheel on the navigator is entirely different
