Timing chain
I have a timing chain with about 1/2 inch play on a model 7. It has been adjusted to the max. Can i replace the chain only or do i have to replace chain and sprockets?
If the teeth are hooked then yes, but doubtful on a chain running on sprockets in clean oil,
