rear brake plate vents
Hello
I have got a rear brake plate with two vents. Each vent has three threads to hold some kind of meshed triangular protection.
Where can I find the screws and the meshed protection?
Enclosed a picture of the rear brake plate.
RenÃ?
Attachments rear-brake-plate-with-vents-jpg
Hi RenÃ?
I have never seen that before on a standard bike, so would suggest it's a modification that someone has done.
I did similar, and found an interesting source for the vents...
...don't laugh!!!!
People that keep their insects and reptiles at home use a heated vivarium - these of course need to be vented (otherwise the contents die)!!!!
A search on eBay revealed an interesting selection of small stainless steel vents.
I have attached a pic of a modification I did!
Attachments rear_brake-jpg
Thanks for the tip. I will try as suggested.
RenÃ?
Previously Grant Tiller wrote:
Hi RenÃ?
...don't laugh!!!!
The holes are the same as the ones in the front brake plate or the speedometer drive. But why two o them?
Were they further out they might be for lining inspection? I know trucks have inspection holes on them.....
I consulted Les at Fair Spares/Norvil as they sell a rear brake 3 vents ki with plates/gauzes. He did not recognize this setup as their own making.
So the search continues.
RenÃ?
