On a Dominator timing cover, there is a threaded hole below the oil pressure relief valve. It was originally for a feed pipe to an oil pressure gauge in the petrol tank. I need to know what thread this threaded hole is.
Also, as an aside, are the open type registration plate brackets as used on bolt-up featherbed frames (1951-54) available?
Paul, Usually whitworth un…
I am pretty sure it is the…
I am pretty sure it is the same as the thread in the cylinder head oil feed holes. Try one of the banjo bolts in it.
On a Dominator timing cove…
Try 5/16" BSF......... as noted by others...same as the top rocker feed banjo bolts. Avaialable from RGM, Norvil, A/Norton etc at about £5 each.
P/N 067696
Yes, it's a 5/16" BSF thr…
Yes, it's a 5/16" BSF thread. I tried the rocker oil feed, a known BSF stud and a bolt. Since the bike uses mostly Whitworth or BSC, it's odd to use BSF here. It must be a standard item adopted.
Threaded Holes - A luminiu…
Threaded Holes - Aluminium Heavy Twin Heads.
All threaded holesare Whitworth form (with 55 degree thread angle).
Dominator, Atlas & Commando - forthe 3 head/barrel studs - 3/8 BSF x 20tpi
Atlas - headsteady centre stud hole - 3/8 BSF x 20tpi
Dominator, Atlas & Commando - intake rocker cover stud hole - 5/16 BSF x 22tpi Dominator, Atlas- 2 oil inlet on top of head - 5/16 BSF thread x 22tpi Commando - 2 oil holes on side of head + 3 headsteady bolts -5/16 BSF x 22tpi Dominator, intake port manifold - 1/4 BSW x 20tpi
650, Atlas and Commando-intake port/manifold - 5/16 BSW x 18tpi Dominator, Atlas & Commando- rocker spindle cover plate screws (pre 66-short) - 1/4BSWx 20tpi
Dominator, Atlas & Commando- exhaust rocker cover studs- 1/4 BSW x 20tpi
Paul,
Usually whitworth unless modified by someone.
Yes, sorry chaps!! I only checked one timing cover quickly and it was helicoiled to 5/16 whit. I checked several others yesterday and they were all 5/16 BSF
