Dominator Wideline Tank Strap Fixing Bolt (rear)
I'm looking for a petrol tank strap fixing bolt which goes through a roller trunnion at the rear of the petrol tank strap. I believe Norton called it a 'petrol tank roller fixing bolt' Part No. 17013.
It's 3.5 inches long threaded 1/4 BSF or 1/4 Cycle (same TPI) for about 1.5 inches. It has a deeper hexagon than a standard bolt, followed by a 3/8in diam shank about .25 inch long. I have seen one with a 2.5 inch shank over which there is a spring which takes up the tension. Knowing Norton there might be quite a variety on the same theme.
At present I cannot find one listed amongst the many stainless steel suppliers. Does anyone know of a source please.
