The response from Andover Norton when I asked if they had plans to re-manufacture the 500/600/650 cylinders. Photo was of a cylinder block. Good news!
Yes, see photo. This is a project that was started when Norton Motors bought the spares side from Mick Hemmings. The tooling that Mick had was for the alloy barrels, but the need is for cast iron, after a few attempts we managed to get the cast iron to flow and have machined the barrel with Hemmings drawing which was totally incorrect as it had liners.
In the next few weeks I will be locking myself away and producing an accurate drawing by reverse engineering the mating part drawings to achieve a barrel drawing, then we will trial machine some barrels.
This has highlighted a few issues from the 50âs, as the original casting used then was for 500, as it pushed out to 600/650 the machining highlighted flaws in these barrels, I have had the luxury of having both barrels, 500 and 650 side by side and the problems are obvious, hole spacing and the tappet tunnels are the areas of concern â the Norton engineers of the day must have had known about them, but with the failure rate of machined castings.
Bruce
I wonder if they would be…
I wonder if they would be spigoted?, those that did not want spigots could have them machined off.What would happen about the dynamo bikes and early bikes with different fin pattern?, lots to think about.
I heard that the club had…
I heard that the club had made some enquiries into having some barrels cast, don't know if there was any progress from that?.
If the club actually manag…
If the club actually manages to commission a batch of barrels for any Norton heavy twin I would faint! Maybe even die of shock!
hello the Original Norton…
hello the Original Norton blueprints from the factory are sat on by Peter Holland And he will not relinquishthem for some reason they're doing No good in his hands when the rest of the club needs them to make parts yours anna j
That is so sad, Anna. But:…
That is so sad, Anna. But: what man has made, man can make again. Reverse engineering jet fighters is a big job - but reverse engineering 1950's Nortons ought not to be. It's not as if they used especially advanced materials. Tolerances are a big issue (inside and outside fit etc) but for the blocks it sounds (from the above correspondence that they were a bit hit-and-miss anyway.
Was there something missing from Bruce's first mail here?
David
Previously David Cooper wr…
David
The only thing missing from my post was the photo. It was of a cylinder block. I didn't think it was important.
Bruce
It's too bad Andover didn…
It's too bad Andover didn't just make them of aluminum with liners as Mick Hemmings did. One could use them as is, paint them silver, or paint them black.
As steel and alloy have di…
As steel and alloy have different strengths its possible that a redesign is necessary , Dunstall Barrels had problems, You can't just make everything thicker, there is not enough room, and if you beef up just parts you can introduce stress raisers and unequal expansion. Unproven pattern parts can be killers. After they have been well tested and sucessfully incorporated in a production line machine you know you have a reliable spare part. Honda 750 cam chain tensioner anyone?.
hello well I think it's time the NOC did something about these factory drawing blue prints we are in need of parts that are not made now so someone needs a wake-up call yours anna jThat is so sad, Anna. But: what man has made, man can make again. Reverse engineering jet fighters is a big job - but reverse engineering 1950's Nortons ought not to be. It's not as if they used especially advanced materials. Tolerances are a big issue (inside and outside fit etc) but for the blocks it sounds (from the above correspondence that they were a bit hit-and-miss anyway.
David
Previously anna jeannette…
Previously David Cooper wrote:hello well I think it's time the NOC did something about these factory drawing blue prints we are in need of parts that are not made now so someone needs a wake-up call yours anna jThat is so sad, Anna. But: what man has made, man can make again. Reverse engineering jet fighters is a big job - but reverse engineering 1950's Nortons ought not to be. It's not as if they used especially advanced materials. Tolerances are a big issue (inside and outside fit etc) but for the blocks it sounds (from the above correspondence that they were a bit hit-and-miss anyway.
David
These places here do accom…
These places here do accomplished work!
http://www.uk-racing-castings.co.uk/
http://www.mfcpatterns-castings.co.uk/page3.htm
Surely any new venture in manufacturing should use modern materials. The barrels ideally should be using suitably aluminium alloys and lined!
There is an accomplished foundry in Sittingbourne or on the Isle of Sheppy, that casts parts for Motorcycle and old cars including the Racing variety!
If they can make barrels in Doncastor for JAP engines what's the big problem about Norton's, except the will to do it and a lack of cohesiveness and planning of the individuals concerned!
Oh! Hang on purists...
John H
Oh! They can scan stuff no…
Oh! They can scan stuff now 3D model it make a hologram type thingy, improve things/design, shove it in a Computerised machining robot and bang you have your stuff, if they can make a Human arm, what's the big problem with an inert set of engine parts?
John H
great theres your answer.…
great theres your answer. someone already in the know. no experimenting with metal types and suitability ect
Barry
Previously Barry Carson wr…
Barry
I presume you mean the "Specialist", all I personally know, is that firms exist that have been doing this kind of stuff for maybe yonks!
On the Vintage car side, stuff is being re-engineered and re-manufactured from obviously, modern metals and using modern production techniques all the time all the time.
You can I have on good authority make things better than the original components with 55-60 years of development available to metallurgists and the like!
Though about constructing a "Home" foundry though as a future thing to do!
John H
John. thats what i meant t…
John. thats what i meant the companys you referred to. they already have the systems in place . it seems daft the club doesn't at least inquire about manufacture of some barrels/cylinders.
Barry
Previously Skip Brolund wr…
plus 1 on that, Skip. Why bother with cast iron barrels any more?
We worked with MFC Pattern…
We worked with MFC Patterns for many years, Mike the father could make a pattern for anything if it was at all possible. The last time I was at his works he was making a pattern for a replacement armrest for Concorde, it was almost finished when they pulled the plug. Send him a sample and get a price.
Dick
Why has no one from our EC…
Why has no one from our EC been on here to update on the abysmal spares situation and pre Commando barrels as a case in point?
My current project, a 57 Model 50 was 8 years doing nothing until a member from Australia had some engine plates made for me. (Thanks Ian) Skip B got hold of a very rare bracket for me and the rear mudguard and headlamp shell came from NZ. (Thanks lads)
The shortage of barrels as mentioned above has been going on for years. About time the club explained themselves.
Previously Neil Wyatt wrot…
Hello All We do know that the EC team Are all volunteers and in most academical circumstances they can short thing out But The Hard to Find Parts Now Desperatelyneed looking at I will volunteer my time if the EC give me the authority and financialbacking and I can keep them updated as we go , but it's up to the membership and the EC to do something But the Noc EC teamseems to put the Cart beforethe Horse, Has I now am only working part-time some 20 hours a week and only paidminimumwage So this meansI am restrictedto how much I can do, with my finances, But still willing to try help out the Club yours Anna JWhy has no one from our EC been on here to update on the abysmal spares situation and pre Commando barrels as a case in point?
Joe S of Andover mentioned…
Joe S of Andover mentioned on these pages about new parts needing to be commercially viable and that is not always going to be the case with regard to much needed non available bits for old Norton's. Not much use then. Sorry Joe.
However, I had a chat with Roger at RGM a couple of weeks ago and surprisingly he was upbeat about supplying to demand, regardless of the viability. This is called providing a service.
In reality, club officials should be having this chat with the likes of RGM, armed with a list and templates where possible, if not; drawings.
When are they going to get started?
Hello Never is the answer to that, But when it comes to a new Spares Van £20k is a mediately set aside, But the more important things like saving a very rare Norton Or getting near impossible to get, part made is overlooked by the EC And they tell us in there Add join the Norton owners club we can help you, yes right when I have ever needed help with parts you cannot get its others outside the club that helped out, and they say this club all about restoring Nortons and their history now what a laugh that is, Us members are on our own mate, we have do things our selfs has this club seems to have littleor no interest in us members ! yours Anna JJoe S of Andover mentioned on these pages about new parts needing to be commercially viable and that is not always going to be the case with regard to much needed non available bits for old Norton's. Not much use then. Sorry Joe.
I wonder where the main co…
I wonder where the main costs lie? Firms like:
http://www.mfcpatterns-castings.co.uk/index.htm
can obviously do it. I wonder where the costs lie?
There are various stages:
drawing (which would need to be done from scratch based on measuring an existing barrel - but is not all that difficult to do privately)
pattern making. Is that done nowadays quite cheaply by 3-D printer direct from drawings? Or more expensively the old fashioned way by a skilled craftsman in wood? An existing barrel cannot be used as a pattern because the casting shrinks as it cools down.
casting - probably the simplest bit of the process in that castings might be made as part of a batch of other simultaneous products
inspection (don't want too many flaws - maybe the original manufacturer did not bother much with inspection, but allowed guarantees to fix any problems that arose?)
fettling and final machining - maybe the most expensive bit?
Of the above, the casting/inspection/fettling/machining should be much the same per casting for small or large orders, shouldn't it? But the pattern making is probably a major one-off cost to begin with. On the other hand - it's the bit that a skilled home craftsman can do by himself.
Of course there would probably need to be at least a few out-of-tolerance prototypes before the pattern is refined.
But how big is the market? That's a really big unknown in any business case.
We cannot expect Commando owners (who must be the majority of the club) being happy to see thousands of pounds spent ("invested") in a project to provide half a dozen barrels, can we? But can any parts of the investment (expenditure) be short-circuited by amateurs or ex-professional club members?
You said it, David: A Comm…
You said it, David: A Commando Club.
I do have a Commando but what about support for my (Our) other machines? They are all Norton's. (In my case)
Still no comment from the EC.
ive given up trying to find any new /good cylinders. perhaps it was the same years ago none available thats why they placed a triumph engine in instead.
was there a photo somewhere
Barry
